Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-21-2004, 09:20 PM
sosotwo's Avatar
sosotwo sosotwo is offline
1948 Ford F-100
sosotwo is starting off with a positive reputation.
Question piston clerance
what whould be exceptable clerance between piston and cylinder on a 239
I just took a 239 apart and ther is a lot of space between them I have a set of 30 thou over pistons that seem to fit good
I should mention that the moter had no compresion that is why I took it apart
could be someone,s quick sell fix?
  #2 (permalink)
Old 04-22-2004, 12:29 AM
mtflat mtflat is offline
Garage is empty, add now
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Time to get out your caliper. The shop manual shows the max manufacturer's bore diameter as 3.1899 or clearance between piston and cylinder wall as .0099
.030 over would make your pistons 3.210 plus .0099 makes 3.2199" If your bore is in that neighborhood you should be good. Remember if you're too close to piston size that expansion occurs with heat from combustion. Rings should have about .015" end gap when installed.
  #3 (permalink)
Old 04-22-2004, 06:33 AM
sosotwo's Avatar
1948 Ford F-100
thanks tim just what I needed to know
I will mesure them up today
with any luck I might have a running truck soon.
  #4 (permalink)
Old 04-25-2004, 09:06 AM
312 312 is offline
312 is starting off with a positive reputation.
there,s no way a set of 030 pistons will fit in a stnd,bore.are they going all the way down.if they are your block is oversize.
Tags
clerance, piston
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
