Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-20-2004, 04:52 PM
missourimudduck is starting off with a positive reputation.
86 f150 300 to 429 swap
I have an 86 ford f150 2wd that has a 300 with 297000 miles. I am thinking about rebuilding a 429, that was in my 71 galaxy 500, and installing it into my 86. What kind of problems am I looking at? Will the motor mounts for a 460 in the same year work? What ignition system should I use?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-22-2004, 03:19 AM
Superdave is starting off with a positive reputation.
Yes the frame mounts and the engine mounts will work from an 83 up F -series truck.
__________________
Superdave
95 Ford F-150 4x4, XLT, 5.0L, A/T
82 Ford F-250 4X4, XLT, swapped 468 CID, C-6 A/T-B&M Shift kit, 8700lb GVWR, Black & Silver
  #3 (permalink)
Old 04-23-2004, 12:46 AM
justshootme84 is starting off with a positive reputation.
That's a really good choice of engine swap, and the 429/460 mounts will work. Look at the MSD 6A ignition system for an upgrade. Just remember to try to find a tranny that will bolt up to the big block motor.
__________________
84 Bronco XLT, 460, C-6, Dana60, Sterling 10.25", 36" GYR RT-II's, Herculiner, S&W 10-pt cage kit, PRP racing seats, Skyler softtop, "Shaker"
88 Bronco Custom, 302 EFI, C-6
86 Bronco Custom, 300 I6, NP-435
78 Bronco Custom, 351M, NP435, 38" TSL's
79 F-150 4WD, 351M, C-6, 35" MT's
  #4 (permalink)
Old 04-23-2004, 02:27 AM
Icicle's Avatar
Icicle has a good reputation on FTE.Icicle has a good reputation on FTE.Icicle has a good reputation on FTE.
Will he not have issues with suspension components on a truck that was designed for the weight of a 300-six going to a 429?
__________________
WoW Server is down, So Im on FTE......
  #5 (permalink)
Old 04-24-2004, 10:36 AM
bremen242's Avatar
bremen242 is gaining momentum as a positive member of FTE.
I would get a set of new front coils that came on a 2wd 460 f250... that will take away any sag..
__________________
http://mav.wastegate.net
'00 in the drive, '85 F250 that runs, '84 F150 in the weeds, minus 1 '85 F150- I finally got rid of some junk..
  #6 (permalink)
Old 04-24-2004, 01:56 PM
oldhalftons's Avatar
oldhalftons has a good reputation on FTE.oldhalftons has a good reputation on FTE.oldhalftons has a good reputation on FTE.
A 429/460 only really weighs about 50lbs more then a 300. fully dressed 300's are close (really close) to 600 lbs.
  #7 (permalink)
Old 04-24-2004, 05:56 PM
bremen242's Avatar
halftons- you probably right, but if his front is sagged, an extra 50lbs won't help..
other than the ride height, there really isn't anything else you'd have to worry about..
__________________
  #8 (permalink)
Old 04-26-2004, 04:56 PM
already have a set of front coil springs with a 2.5 lift from an 86 f250. Thanks for the input
  #9 (permalink)
Old 04-26-2004, 06:21 PM
82F100SWB's Avatar
82F100SWB is gaining momentum as a positive member of FTE.
A 460 weights more than 50 lbs more than a 300, Ford Power Products(industrial engine devision) specs a 460 out at 715 lbs, and, a 300 out at 495
__________________
86 F250 HD, 4x4/460/T19/44HD/10.25
82 F100/86 F350 4x4 460 with some goodies/T19 D60/welded 10.25/38.5 Boggers, mud racer/wheeling pig...
81 F100/86 F250 HD 4x4, 6.9/T19/D44 TTB junk/10.25. All smoke, no power, turbo no more...
And a couple Brand D's with early "C" power
It's not what you BUY, It's what you BUILD
  #10 (permalink)
Old 04-26-2004, 06:57 PM
i know a FE is close to 700lbs fully dressed and thats about 40lbs MORE than a dressed 460.
I wonder what they bolt on to them to get the 715. 495lbs for a 300 must be a longblock shipping weight.
a 300, complete fan to flywheel, aircleaner box, manifolds, everything, weighs 597lbs before you bolt it to a pallet.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
