Annoying Buzz from Electronic Brakes?
I have a 2002 F-350, V10, which has newly installed electronic trailer brake control. A continuous "buzz" has started (sounds like it is under the dash). The buzz will stop when the brake is depressed, but starts immediately once you let off of the brake. Any advice will be GREATLY appreciated.
Thanks
Thanks
Its been years since I worked with any controllers.. Can you give us any more info? Did you insstall this yourself? What kind of controller is it? How/where is it mounted?
Could the buzz be relay chatter?
As an off the wall guess, try slightly adjusting the angle at which the controller is installed and see if that stops it...
nymo
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-12-2007 08:49 PM
