tailgate window only works sometimes
Now that it is getting warm out I car do some work on the bronco. How should I go about troubleshooting a tailgate window that keeps stopping and starting at random?
Mine will sometimes work great for weeks at a time then all of a sudden stop all together for a undetermined length of time. Some times it will be fixed by driving around and going over bumps. But the last time it stopped the bumpy road trick didn't help. It suddenly started working again while absolutely still, parked in front of my house. Just repeatedly pressing the button caused it to start moving again.
What is the best way of replacing the wiring to the tailgate? do I have to remove all the interior plastic or is it better to snake the wires through? Does ford have a decently priced replacement wiring kit for this?
Make sure it's closed all the way, there is a switch on the pass side of the tailgate that senses if it's closed all the way. If it's not closed all the way or it thinks it's not then the window motor won't work. Check the wires where they come out of the body and go in to the tailgate, they frequently get frayed/cut and cause these intermittent problems and eventually it stops completely causing most guys to think the window motor is bad.
Mary Kate,
Uscrpick describes something very akin to my experience... the symptoms of which were similar to yours.
As best I can recall, some of the common problems for this intermittant beast are:
- broken wire (inside the insulation) at the flex point(s) of the wiring harness leading into the tailgate... lower left corner of the tailgate.
- the 'closed' limit switch failing.
- ground wire connection in need of cleaning.
- of course the darn dash switch.
Run a search in this forum for 'tailgate window' and similar keywords.. you'll find a *number* of threads with more details.
The wiring to the tailgate runs down the left side frame channel and is fairly well protected. Unless there's physical signs of wear, melting, etc.. the wiring will probably be fine.. with the possible exception of that which runs (and flexs) to the tailgate itself.
Personally, I kinda wish someone had said, "Change the dash switch first.", but then again, that *is* what was ailing mine.
Swit
'94 XLT 5.8
Swit
'94 XLT 5.8
Okay thanks for the replies. I forgot to say that the tailgate-is-closed-switch has been bypassed sense one week after I bought the bronco. (I'm smart enough to not rase the window if the tailgate it open).
So I should double check the dash switch, the motor's grounding point, and the flexy wires leading from the taillight into the tailgate (but not the wires leading into the taillight). Is there an easy way to check the dash switch without using the "replace it and see if it is better" method?
I had a similar problem and noticed it was occurring after it rained. My weather stripping on the tailgate was cracked and in pretty rough shape, probably letting in some water. So I opened the tailgate cover, relubed the gearing, replaced the tailgate rubber/felt weatherstripping and so far (~6 months) no more hiccups. Good Luck.
I had a similar problem and beleive it or not the plastic connector between the window wiring harness and the tailgate wiring harness had corroded and was only getting about ten volts across it.
A good pair of wire cutters, a soldering iron, and some heat shrink tubing cured my problem. I hard wired the motor directly to the tailgate harness.
Built-Ford-Tough91
1978 - 1996 Big Bronco
09-05-2013 05:20 AM
