Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-19-2004, 01:49 AM
Lone_Ranger01 Lone_Ranger01 is offline
Lone_Ranger01 is starting off with a positive reputation.
A true CAI for 01+ 2.3L....a little something I wrote up.
For those of you who want a true Cold Air Intake for you duratec 2.3L. Basically what I did was was flip the intake tube to the other side of the engine. You need to have a K&N cone filter or one similar for this to work. Before starting this, make sure you disconnect the negative battery cable.
Here's the steps:
1. Take off the plastic resonator near the throttle body. It's there to help keep the intake quiet...who wants that. You'll have a hole in the intake tube where it was attached, for some reason some models had two connections to the resonator...in that case you'll have two holes. To patch these holes I used something called a "Galvanized pipe plug" they sell them at Lowes in the plumbing supplies. I used the 2" plug...all it is is a piece of rubber between two round metal plates with a bolt through the center...when you tighten the bolt the plates squeeze the rubber and it expands. I had to put a little oil on the plug to squeeze it in the hole..you gotta work it in there. Here's what the resonator looks like.
2. Next we have to relocate the powersteering res. After you remove the plastic resonator you will notice that it was mounted to an aluminum bracket...this bracket is where the PS Res. will be moved to. All the holes on the bracket line up perfectly with the PS Res, the mounting holes and the threads for the bolts are the same. Remove the PS Res. from the black bracket that it is on and move it to the old Resonator location...you just reuse the bolts that were holding it on. I think the aluminum bracket was meant to be a PS Res. mount originally because it fits perfectly.
3.Next, loosen the hose clamp that holds the intake tube to the throttle body and also unplug the breather hose from the intake tube. Then unplug the MAF harness. Now that that is done just flip the intake tube to the other side of the engine bay (over by the battery) and bend the tube at a 90 degree angle and stick it down by the frame. Now plug the MAF harness back in and make sure you zip tie the MAF wires to the intake to keep them away from the fan and belt. In order for the breather hose to reach you will need about 12-18" of vacuum line to extend it, you could also use some rubber tubing from lowes.
4.Now retighten the clamp that holds the intake to the TB and make sure everything is connected correctly. Check all the bolts and make sure they're not loose. ie: the PS Res. bolts. Give everything a good look over and tidy up...reconnect the battery cable and YOU'RE DONE!!!
__________________
http://www.ford-trucks.com/user_gall...&photoid=35316
2001 2.3 I4 Ranger,5-spd, XLT Stepside, Reg Cab
Loud pipes save lives!
  #2 (permalink)
Old 04-19-2004, 02:28 PM
Traxxis's Avatar
Traxxis Traxxis is offline
1994 Ford Ranger
My Garage
Traxxis has a very good reputation on FTE. Traxxis has a very good reputation on FTE. Traxxis has a very good reputation on FTE. Traxxis has a very good reputation on FTE.
Not bad... good job Lone, nice illustration.
__________________
'94 Ranger XLT Ext. Cab 3.0L 5-speed
'97 Ranger XLT Ext. Cab 2.3L 5-speed
  #3 (permalink)
Old 04-19-2004, 05:05 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE. Ken00 is gaining momentum as a positive member of FTE.
Nice write up, this will make it into the tech info thread.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
  #4 (permalink)
Old 04-20-2004, 07:55 PM
I thought I'd get more replies then this...I guess no one's interested.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
