light/ wiper knobs
Old Apr 19, 2004 | 12:43 AM
82f1504x4's Avatar
82f1504x4
light/ wiper *****
i have 82 f150 im trying to get the dash apart for a new gauge cluster and i cant get these ***** off without breaking them howdo they come off???????
thankks
justin
Old Apr 19, 2004 | 01:02 AM
DanMartin's Avatar
DanMartin
Make a small hook with a piece of sturdy wire (like a small coat hanger or large paper clip). The hook tool will have a small "u" at the end about 1/4" around. Use the hook to go around the back-side of each **** and push on the spring that is holding them in (pull the tool towards you)...they will pop right off. On the headlight switch you'll feel a small cutout on the back-side of the ****...that's where the spring is at it's highest...push there. The wiper one tends to come off easier.
Once you get them off and have a look you'll see how they work...
Dan
Old Apr 19, 2004 | 01:04 AM
82f1504x4's Avatar
82f1504x4
thanks ill give it a shot in the morning
Old Apr 19, 2004 | 06:03 AM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
When you push in the small wire push the **** IN a little as you push the wire in. You have pulled on the **** and the small flexible tab of steel may be trying to dig into the shaft. By pushing in the **** as you push in the wire the bind you have put the holding tab in is released making the wire insertion easier.
Once you relieve the little locking tab the **** comes right off!
Old Apr 19, 2004 | 02:14 PM
DMAN's Avatar
DMAN
Not all of them have a locking tab my 84 f-250 had a set screw in the lights switch ****.
Old Apr 19, 2004 | 02:39 PM
Varnish's Avatar
Varnish
For my '84 f250 you had to push a release spring/pin from under the dash while pulling on the headlight ****. This would pop the whole shaft out with the ****, you then could use a cutoff piece of hangar to turn the lights off.
hermannm2
2009 - 2014 F150
Sep 26, 2013 03:08 AM
LouisianaKid
Aug 29, 2011 07:52 PM
tmwindham
1978 - 1996 Big Bronco
Oct 24, 2004 12:10 AM
69man
Aug 8, 2000 08:43 AM
