96 P1443 EVAP purge valve fault
I have a 96 Ranger, the check engine light keeps comming on. I pulled the codes with a Snap On scanner. It reads EVAP Purge Valve Fault. I have replaced the Evap Purge valve and Carbon Canister. The vapor lines are not cracked or plugged. After I changed the parts I cleared the codes out of the system. I drove it up the road a ways and the light comes back on. Does anyone know what the problem could be.
This thread from the 3.0L V6 Forum might help:
https://www.ford-trucks.com/forums/s...hreadid=152825
