360 Exhaust Manifold bolts - Ford Truck Enthusiasts Forums
Old 04-18-2004, 09:23 AM
offroaderone offroaderone is offline
offroaderone is starting off with a positive reputation.
Are the top holes for the exhaust manifolds threaded? Mine had bolts through the top with nuts on the back. I can't get a tap to run through them either. Thanks
Old 04-18-2004, 09:54 AM
Ratsmoker's Avatar
Ratsmoker Ratsmoker is offline
Ratsmoker is starting off with a positive reputation.
Originally the head was threaded but the top bolts are very rust prone and sometimes people will drill them out and use a bolt and nut to clamp them together. The actual manifold bolt holes are not threaded.
Old 04-18-2004, 10:25 AM
gtex's Avatar
gtex gtex is offline
gtex is gaining momentum as a positive member of FTE.
They should have been threaded. I believe it's a 3/8" bolt. If they put a smaller bolt all the way through, it may have helped corrode the threads.
Turbo/Exhaust bolts and hardware bluemtn95ford Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 01-05-2016 06:38 PM
Exhaust bolt thread repair Simaverick72 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 11-21-2014 06:19 PM
Exhaust bolt thread repair Simaverick72 1967 - 1972 F-100 & Larger F-Series Trucks 3 11-19-2014 09:16 PM
Exhaust manifold bolts breaking mowman98 1999 to 2016 Super Duty 5 09-24-2014 12:41 PM
08 F450 drivers side exhaust manifold Odakrem 1999 to 2016 Super Duty 3 08-06-2014 02:18 PM
Tags
360, bolts, exhaust, f100, ford, manifold
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
