Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-16-2004, 11:37 PM
Want2Bfordman is starting off with a positive reputation.
351 Cleveleland Intake
I got a Weiand X-celerator 7517 intake for my 351C 4V engine. I am building this from a bare block and no parts btw so I am not completely stupid! LOL Anyway when I set the intake on the engine I notice the intake will not sit flush due to what looks like guides/studs in the heads near the intake port, each head has one... I do not have a gasket as the Full Set was almost a full set! LOL When I look up the gasket it says .060 thickness and these guides are much thicker. There are no holes in the intake and I am using the right intake and heads... Am I missing something in the casting of the manifold or do these guides/studs work out with the gasket. Also I notice a hole in the middle of each head that will not be fully covered by the manifold. From what I have seen looking at the gasket residue on blocks for sale online it appears these hole do not get covered up...
Any info will help as I do not have a parts list... I don't think it matters much about the casting #s because every set of 351C heads I have seen have this guide/stud but FYI I got DOAE quench heads...
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-17-2004, 06:09 PM
mark a.'s Avatar
mark a. is gaining momentum as a positive member of FTE.mark a. is gaining momentum as a positive member of FTE.
I think what your talking about is a small pin maby 3/16.Each head has one. If so its used to keep the stock tin pan intake gasket in place while assembling. If your using 4 piece gaskets you could probably pull them out if there in the way.The intake is supposed to be below them when it's bolted on. I had a after market intake one time, I don't remember now what brand it was, but I ended up grinding it some so it would get by the pins. Those holes your talking about don't go anywhere, you don't need to do anything with them.
  #3 (permalink)
Old 04-17-2004, 09:21 PM
stevef100s is new and has a neutral reputation at this point.
Hey Dude. Nobody would accuse you of being completely stupid. If you were, you would be on a different site asking about a Chevy problem. LOL
  #4 (permalink)
Old 04-18-2004, 02:05 AM
Thanks guys! Got it all together now. I just heated up the heads and tapped them in and blended them into the casting with a polishing tool... No chance of an oil leak this way...
  #5 (permalink)
Old 04-18-2004, 09:12 AM
Icicle's Avatar
Icicle has a good reputation on FTE.Icicle has a good reputation on FTE.Icicle has a good reputation on FTE.
drooling over the thought of putting a 351 cleveland in wifes truck instead of rebuilding and hopping up her 302.....a 351 cleveland, now theres something fun and different
__________________
WoW Server is down, So Im on FTE......
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
