You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Okay, so I am a novice, but is the thermostat REALLY located on the lower left hand corner of the engine. I have to replace it and I find it a very difficult place to get to. 1999 Ford Ranger Sport, 2.5 L four cylinder with AC and PS. THanks.
Should be front & center at the end of the upper rad hose. Also not an easy location to undo the bolts.
__________________
97 Ranger (metric half ton) 2.3,5spd. Saphire blue metalic w/matching cap & Stock Rims 4 winter.
92 Town Car....Sweet PITA.
90 BII 4x4 Ongoing Project, aka PITA
63 Fairlane, Gone to my buddy Chuck.
It Aint Fun Unless It's Done The Hard Way!
Thanks, I would logically look for it there. I bought a Chiltons Book for 1991-1999 rangers and it said look below. There is a heater hose and the lower rad hose going into a housing, but wow it is hard to get to. Thanks for the help.
The book that I have ends @ 97 (mines a 97).
It just doesn't seem practical to me that they would do a major change like that. There's also a heater hose to the thermostat housing shown. I can't presently think of any engine with the t/stat on the lower hose.
__________________
Thanks a lot. Then I am going to proceed with the taking off the top hoses and let's see what happens. I too had not heard of a thermostat down below. And the top one does have the connections for the heat sensors....it seems the proper place. Thanks a ton for taking time to help me out.....
I posted a message about the same thing (thermostat location on a 99 ranger) aswell. I don't ever remember getting an answer from it, maybe i just forgot to re-check the post. But this helps me out too. Thanks!
__________________
Phil
1999 Ford Ranger, Reg Cab, 4x2, 5 Speed Manual w/ OD, 2.5 ltr. 4 cyl
http://www.cardomain/id/Diabolic
Well I found the thermostat, just where you said it would be, but no one seems to have the right replacement part. Just make sure if you do this on your own, you have a buddy that can find a ford dealership quickly. Thanks for all the help.
