How often do you need to change shocks? - Ford Truck Enthusiasts Forums
Old 04-16-2004, 03:00 PM
wickymustang wickymustang is offline
wickymustang is starting off with a positive reputation.
I have a 1995 F150 4.9 2wd with 84,000 miles, I don't know how old the shocks are, how often do you need to change them? I ask because come fall I am going to college in Fargo and I want to be sure I have everything good and ready to go.
If I need to change them, what do you guys think about RanchoRS5000's?
Old 04-16-2004, 03:15 PM
threefiftyone's Avatar
threefiftyone threefiftyone is offline
threefiftyone is starting off with a positive reputation.
Does your ride suck? A bone jarring ride, squeaks and rattles develop when shocks fail. RS5000's have served me well on my Bronco.
Old 04-16-2004, 07:37 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Depends on the vehicle and the conditons it is used under. If you live in a salt state with rough roads, 40k-50k. Highway driving you can get 100K plus from a set of shocks.
Old 04-16-2004, 10:04 PM
Ecuri Ecuri is offline
Ecuri is gaining momentum as a positive member of FTE.
Bounce the corner down by standing on it and jumping off. It should sink and return to normal with minimal or no oscillation. I like my RS5000's a lot.
Old 04-19-2004, 07:56 PM
Are they adjustable to different settings? And if so what would you guys recommend for mostly city and some highway driving? And what about for running gravel and logging trails? What about Heckenthorn Hydro 8000's are they any good?
Old 04-20-2004, 11:27 PM
tdister's Avatar
tdister tdister is offline
tdister is gaining momentum as a positive member of FTE.tdister is gaining momentum as a positive member of FTE.
I would recomend the bilsteins if you can swing them. Lifetime warranty, and excellent performers in every vehicle I have driven/ installed them on(understatement). I liked the Rancho 5000's my sisters truck had (also a 4.9 f-150), but three bushings were gone in less than 25K miles, I've also heard the same thing from several dakota(my previous love) owners. there is another shock thread in the 97 up forum w/ my experience w/ bilteins on my 99 here: http://www.ford-trucks.com/forums/sh...ad.phpt=231025.
No, experience w/ the Heckethorns, but almost anything is better than stock. from the sound of your 2nd post the Bilsteins are the way to go.
50 F4 on Fargo C/L toby tough 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 02-09-2014 02:12 PM
Mud runs? ExtrmZ North Dakota Chapter 3 12-30-2011 04:38 PM
61 Unibody. Is it worth it? toby tough 1961 - 1963 F100 Unibody 5 10-11-2011 06:46 AM
Wells Fargo "Warranty Solutions" Extended Warranty MCDavis General Automotive Discussion 16 10-07-2010 06:30 PM
Second Alternator installed yesterday-No whistle/squeal when cold for now... AB328 2004 - 2008 F150 13 02-09-2007 02:45 PM
Tags
08, 2005, 4x4, change, f150, f250, f350, ford, recommend, replace, shock, shocks, suv, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
