4.5L V6 Powerstroke
Originally Posted by 99F150
HAs any one attempted to install one of these baby powerstrokes into a F150? I had read that Ford was testing this engine in the F-150 and Expedition a couple of years ago. I would like to put one in my 99F-150 , they are rated around 230HP and 300LBFT torque.
Dan
Dan
Engineered and produced in North America, the new Ford LCF is designed for use in highly populated urban areas, where more and more customers are turning to tilt cabs for their general delivery, utility, recovery, leasing and rental, construction, landscaping and other vocational applications.
It’s built for customers who appreciate the tilt cab design advantages over conventional cabs—visibility, maneuverability, operating ease, overall efficiency and basic economics.
U.S. industry-standard 34" frame width and optional axle-to-frame (AF) dimensions help make upfitting easier and more cost-efficient.
Power and Performance
The Ford LCF will have plenty of horsepower (200) and torque (440 lbs.-ft.) to haul the heavy loads, climb intra-city hills, or merge onto freeways safely. Power and frame, suspension, and brake designs all contribute to a robust, Built-Ford-Tough chassis that delivers excellent maneuverability, braking and brake wear, and ride and handling.
Basic Specifications
GVWR: Classes 4/5: 16,000 lbs., 17,999 lbs. and 19,500 lbs.
Cab: Ford
Engine: Power Stroke® 4.5L V-6 Diesel; 200 HP @ 3000 rpm; 440 lbs.-ft.
Torque @ 1850 rpm
Transmission: TorqShift™ 5-speed Automatic O/D with Tow/Haul function
Transmission-Mounted PTO provision: optional
Wheelbases/CAs: 113"/84"; 137"/108"; 149"/120"; 167"/138"; 185"/156"
Frame Rails: Ladder type, Huckbolted, High Strength, 50,000 lbs. psi
CA (Cab-to-Axle): clean top of frame rail for easy body mounting
Axles:
Front: I-Beam 6,000 lbs. /7,000 lbs.
Rear: Single-speed 11,000 lbs. /13,500 lbs.
Suspension:
Front: Taper-Leaf, 6,000 lbs. /7,000 lbs.
Rear: Vari-Rate 11,000 lbs. /13,500 lbs.
Brakes: 4 wheel anti-lock disc
Stabilizer Bars: Front and Rear
Fuel Tank: 40-gal. (rear-of-axle between rails) std./35 gal. single/dual (side)-optional
Wheels – 19.5" (Steel or Polished Aluminum Wheels) and Tires
Tow Hooks
Chrome Grille/Headlamp Bezels: optional
International also made this same truck too. The international CF sieres. The same specs as above and both trucks will be avalible in early 2005.
Thanks for the reply, from some friends of mine that work for International they say this engine has been around for a while already. Maybe Int. did some changes? I am tired of paying the high price and low MPG of gas but do not need a larger truck. Some people have also sugested installing a four cyl. Diesel from Cummins. They can be had with up to 200HP and 325 lbs torque. This would be plenty of power and the fuel economy should be high?
Dan
Dan
Powerstroke9292
06-15-2015 12:02 PM
45, 45l, af, diesel, dimension, ford, horsepower, international, liter, power, powerstroke, stroke, truck, trucks, v6
