6.9 ltr. Diesel Torque
[updated:LAST EDITED ON 09-Nov-02 AT 11:19 AM (EST)]First of all, I would like to thank all of the folks who have responded to my previous posts!
Now my question:
Does anybody know how much Torque/rpm the 6.9 ltr. Diesel is rated.
Is cavitaion also a problem for that engine and how can I test wether an additv is added in the coolant? I've heared from a kind of teststripes to check it
What is the best addidiv available?
thank you for your help.
Jens
Now my question:
Jens
>Now my question:
>rated.
>Jens
You can pick up the test strips at any good diesel shop.
This will tell you if it currently has additive in the system. I was using Ford FW-16, but have since switched to a Fleetguard Pre-Charged coolant filter with 8 SCA units. This way I don't have to worry about if the level is up to snuff or not, it's always there, plus I know that the coolant is clean. You can read about my install on my website.
http://mywebpages.comcast.net/argve1...%20Filter.html
Specs.
The Spec. book for non-turbo shows 168 hp @ 3300 / 317 ft# @ 1400 or the high alt engine 150 hp @ 3300 / 287 ft# @ 1400.
>Now my question:
>rated.
>Jens
Specs.
