What kind of lube do you use on your hitch ball?
Originally Posted by jim henderson
I use plain old wheel bearing grease. I also periodically wipe off the old grease since it picks up dirt. Also use this grease for the weight distributing hitch transfer bars.
Jim Henderson
Jim Henderson
Edmo
i bought a few packs of the hitch ball grease before i made my first cross country trip last year... and that is some THICK stuff. it seems like it goes on almost like antiseize, but after a day of driving, it was a real thick.
it was more expiensive than bearing grease, and it was not as easy to keep clean when i got finished with it(b/c i didnt use a whole pack), and worked just as well.
i dont see any need for me to buy anymore of the over priced stuff. bearing grease is just fine for me.
Jim Henderson
Jim Henderson
Originally Posted by 85BigBlock
where on the bars do you put the grease?...just where they contact?
On my Eaz Lift weight bars, I put a light coat of grease on the part that slides up inside the reciever. I also put a bit more in the groove on the end of the bar that goes in the reciever.
I also lube the ***** on my sway bar, BUT NEVER the sway bar itself.
I usually clean out the inside of the ball recievers periodically since they do pick up a lot of grit sometimes, especially at the beach. Also a good idea to clean the inside of the reciever for the bars. I have noticed some metal to metal wear in there due to grit etc.
I also put a little silicone grease inside the connector hosuing for the trailer wiring. Makes it much easier to plug in and unplug.
I periodiclaly spray some lube into the Screw Closed Chain Links that connect my chains to the reciever. I forgot what they are called but look like a link in a chain with a screw treaded barrel which allows you to open and close the link.
Once in awhile clean and grease the screw jack on the trailer A frame. Also the screwjacks on the 4 corners.
All of this takes maybe 5 minutes and can be done as you are setting things up at a camp ground or whatever.
Good Luck,
Jim Henderson
