Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-15-2004, 07:02 AM
jadel is starting off with a positive reputation.
switch for glo plugs
helo there
Iread in a post that some people have a switch to turn on there glo plugs.I was wondering what the reason for this is,and also I have a 94.5 psd and I'am
getting the glo plugs and relay switch replaced on it the mechanic said the relay seems to be sticking on and does not want to take a chance on just replacing the glo plugs in case it sticks on and burns the new plugs out so he is going to replace it.I'am a new owner to this truck and there is a switch somebody added to the dash and I wonder if this is what is making the relay stay on if the switch is left in the on position.This is probable cause to the problem to begin with.Please reply thanks
  #2 (permalink)
Old 04-15-2004, 08:44 PM
c_nate is starting off with a positive reputation.
put a switch on the glow plus so I did have to wait till they shut down to start the engine. starting the engine with the plugs still on will make em distort and or fail. Also when the engine is warm. No need to bother with having the possibility of them turning on at all.
what I did was a 3 position switch,
the up position was a momentary contact and forced the glo plugs on.
the center position was all off (non connection)
the bottom position was to allow the glow plug controller to take over.
This was all wired into the glow plug relay so the switch didn’t take the big current the plugs draw.
Nate
__________________
1994 F250 4x4
7.3 IDI factory turbo
  #3 (permalink)
Old 04-15-2004, 09:00 PM
Thanks for your reply.But when the light goes out on the dash,is it not safe to start the engine then or should you wait longer.Can somebody please explain.
  #4 (permalink)
Old 04-15-2004, 09:53 PM
when the light is out, the plugs are off. so it is then safe to start the engine.
__________________
1994 F250 4x4
  #5 (permalink)
Old 04-16-2004, 09:35 PM
thanks for your reply c nate.It is always nice when somebody replies.
  #6 (permalink)
Old 04-19-2004, 10:56 AM
Saigon's Avatar
Saigon is starting off with a positive reputation.
Thumbs up Glow plug manual switch
Hi,
Here is a link to the "official" bypass switch for glow plug manual control,check and see if yours is hooked-up this way.You have to use a "temporary switch" that will spring back to the "off" position once you let it go or else you will fry your plugs.Hold the switch "on" for 5 or 6 seconds and fir it up.
Saigon
http://www.members.shaw.ca/k2pilot/G...%20diagram.jpg
  #7 (permalink)
Old 04-19-2004, 11:56 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
The switch should be a momentary switch, I intend to leave mine there permenetly.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #8 (permalink)
Old 04-20-2004, 05:16 AM
Saigon's Avatar
Thumbs up Switch
Me too,
Had too many problems with the original GP controller, it came on a few times while driving and fried the gp's, I was lucky none of the tips stayed in the cylinders!! I wouldn't change my manual switch for anything !!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
