Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2004, 09:51 PM
jkorreck is starting off with a positive reputation.
Question bending exhaust pipe
I was wondering if anyone has any tips on how to bend exhaust pipe with a pipe bender, it seems to smash the pipe alot before it bends. I've heard recently that you need a tube bender to really do quality bends in exhaust any advice?
  #2 (permalink)
Old 04-15-2004, 06:54 AM
V10man's Avatar
V10man is starting off with a positive reputation.
Buy prebent pieces from JCWhitney?? Mandrel bent is so much better.
__________________
2007 Dodge 3500, 6.7L Cummins, A/T, exhaust brake, 4x2, long bed, white.
1992 F150 4x4, 5.0, a/t, stepside, K&N, Flowmaster, 93,000 miles
  #3 (permalink)
Old 04-15-2004, 07:05 AM
I'll do that once I get the money together for a good exhaust system. Right now I'm trying to do a cheap fix. I have a 92 aerostar van that I got for free a couple months ago and the muffler and flex pipe have rusted to the point that they look more like swiss cheese than anything else. Any advice on the actual bending and if it can be done somewhat decently with a ram style pipe bender?
  #4 (permalink)
Old 04-15-2004, 08:21 AM
Read only
Ford79 is gaining momentum as a positive member of FTE. Ford79 is gaining momentum as a positive member of FTE.
I haven't had any luck with trying to bend exhaust tubing on my pipe bender, it just flattens it. What I do if I need a piece of pipe bent, I bend a stiff wire (clothes hanger)in to the shape I need and approximate length and take it to a shop to have the pipe bent. This will get you pretty close to what you need, and doesn't cost too much either.
__________________
Mike
2001 F350 CC LB 7.3 Powerstroke
Dp Tuned, 5"
  #5 (permalink)
Old 04-15-2004, 01:14 PM
Skagit is starting off with a positive reputation.
Depending on how much bending you are doing, and the diameter, you could fill the pipe with sand, pack it in good, and plug off both ends. Should keep it from collapsing, but a exhaust tube bender might work better if you are going to make alot of bends. Good luck.
__________________
Ford's Don't leak ,
They Mark Their Territory.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
