Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2004, 08:44 PM
jroehl's Avatar
Mastposter
jroehl is a splendid one to behold jroehl is a splendid one to behold jroehl is a splendid one to behold jroehl is a splendid one to behold jroehl is a splendid one to behold jroehl is a splendid one to behold
So I'm about to take my heads off...
'90 F150 4x2 302 EFI. I've heard that one needs to have the intake manifold ground to fit the heads if they are ground at the machine shop. Yea/nay?
But, before I tear into the heads, let me tell you what I see. The intake plenum was wet with anti-freeze, and a little gas. The intake manifold has AF in the dead spaces between the ports and the heads (sitting on top). And this baby was whizzing AF once warmed up, but I couldn't tell exactly from where. The oil dipstick had rust on it, but I couldn't really see any AF in the oil.
So am I looking at a likely blown head gasket (forgot to check compression), trashed valves, etc.?
Engine has 143k on it, but was short-blocked at 93k.
Any comments, questions, concerns, tips, tricks, etc. would be greatly appreciated.
Jason
  #2 (permalink)
Old 04-15-2004, 08:51 AM
jwtaylor is starting off with a positive reputation.
If they do resurface the heads you shouldn't need your intake resufaced. Good luck
  #3 (permalink)
Old 04-15-2004, 03:04 PM
Ford427Strokr is starting off with a positive reputation.
usually if the heads are milled they will also mill the intake side of the heads to match up with the intake.
__________________
92 F150 306ci 5.0 E303 Cam 10.8 Comp. with Windsor heads March Underdrive Pulleys BBK Throttlebody Flowtech Headers Full MSD Custom Hypertech Chip 4.10 Gear Bullet Proof E4OD with 2500 stall
  #4 (permalink)
Old 04-17-2004, 01:27 PM
94F150-408 is starting off with a positive reputation.
Blown head gasket or manifold gasket, worse would be a crack, you'll likely see where it's coming from once you remove the heads.
While your cylinder heads are apart, you might consider doing a quick port match and bowl clean-up to gain some ponies.
__________________
94 F150 4x4 393 Stroker
95 Bronco- 408 SuperCharged
Mods in Gallery
  #5 (permalink)
Old 04-17-2004, 06:22 PM
jroehl's Avatar
Mastposter
Quote:
Almost there. Still have to disconnect the exhaust manis from the headers (pass side ex mani broken, to top it off...grrrr....), then just pull the heads--all the rocker arms and rods are out already.
And a port match and bowl clean-up would be...?? I don't do a whole lot of this, I'm just trying to put this truck in halfway decent running order so that I can sell it. It's already been replaced by a '93 F250 2wd 351 auto 4.10 xcab LB. I sure like the step up in HP/Tq, but that 4.10 is really hitting me in the wallet right now. Once I sell the F150, I'll probably put in a 3.55 and a locker, since it seems to have an open diff.
Jason
  #6 (permalink)
Old 04-17-2004, 06:46 PM
Quote:
Not worth doing if your just puttin her on the chopping block. Its porting and polishing that requires a fair amount of elbow grease....better to save a project such as that for a vehicle you want to keep.
Let us know when you find your problem, hopefully its nothing more than a gasket!
__________________
Mods in Gallery
  #7 (permalink)
Old 04-18-2004, 06:06 PM
Capone is starting off with a positive reputation.
You may also have a leak in the TB assembly, where it mounts to the intake...
and with the engine's vacuum it can be pulled down into the upper to lower gasket area...via intake runners and sits there pooling...
this is the only way I can think of coolant getting upstream from where the leaks usually happen.....the intake to head mating surface...
Take the TB off and inspect the gasket surface carefully...you should see some signs of leaks from there.
To answer your question about milling heads, yuo usually don't have to mill
the intake at all if this is the first time milling the heads...
the only exception is that you are taking significant material off the heads...only then do you have to compensate on the intake.
__________________
88 E. Bauer Bronco 5.8
List Mod's in Gallery
  #8 (permalink)
Old 04-19-2004, 09:29 AM
jroehl's Avatar
Mastposter
TB has been off for a few days now. Got the heads off last night, and while the gaskets looked pretty good, there was a small area where the metal was de-laminated from the paper--pretty small and I almost didn't see it.
The intake to head surface sure looked pretty gnarly, though--lots of crud and the gaskets were pretty mushy (not obviously "blown", though), but that could very well have been it.
Anyway, since the heads are off, they're going to the machine shop, probably have a valve job done on them, and I know this is the at least the second time the heads have been off, but I don't know how much they were milled the first time. The first time they were off is because the #8 piston decided to get married to its valves , but only a little bit at a time.
Another Q: I heard once that exhaust manifolds can be welded back together? True or not? I replaced the driver's side one last year, but I'd rather not have to pay another $170 for the pass side manifold if it can indeed be welded. It's broken clean through between #3 and #4, and looks like it was that way for at least a little while (carbon coating on the entire break), but it wasn't noticeable noise-wise like the other one was when it broke.
Thanks,
Jason
  #9 (permalink)
Old 04-19-2004, 10:51 AM
most cast iron welding used to be done with a welding rod with very high nickle content after heating the item to be welded on. I'm not sure if they have improved much on the welding of cast iron or not. It wasent a very strong weld back in the 70's, anyone had any more recent experience on this may be able to say if it will be an effective repair or not.
__________________
Mods in Gallery
  #10 (permalink)
Old 04-19-2004, 11:05 AM
TeulonF250 is starting off with a positive reputation.
i use M + R alloys 800 series rods and they are the best i have used. they seem to be stronger than the original base metal with no side effects. i've welded evrything from manifolds to trannies with this wonder series of rods. they're not cheap but you get what you pay for
  #11 (permalink)
Old 04-19-2004, 12:55 PM
TeulonF250, these rods work on cast iron or just steel? Do you have to preheat the cast iron as with nickle rods? Sounds like it might be the ticket if it works on cast iron.
__________________
Mods in Gallery
  #12 (permalink)
Old 04-20-2004, 09:27 AM
jroehl's Avatar
Mastposter
Grrrr....just got a call from the machinist--BOTH heads were cracked. At least that explains all the coolant leaking out (and probably both exhaust manifolds cracking in two over the past year or so).
Of course, now I have visions of custom work dancing in my head (no pun--), but I'd better just fix it and sell it so that I don't end up sleeping in it.
Jason
  #13 (permalink)
Old 04-20-2004, 12:36 PM
hummm...if you kept it, ate mac and cheese for awile, aluminum heads, headers...hummm
__________________
Mods in Gallery
  #14 (permalink)
Old 04-20-2004, 08:40 PM
jroehl's Avatar
Mastposter
I'd be sleeping in it because SWMBO would make me....she's already not too happy about the ~$700 I'm gonna have in it after I'm done. (At least I got a decent torque wrench out of it ).
Jason
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
