Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2004, 04:22 PM
Babin is starting off with a positive reputation.
Unhappy Is it the king pin?
Hello people! You're talking to a newbe.
I own a e-150 1987 with 550 000 km (about 344k miles). I had an accident recently. The right wheel was badly hit from the front while the wheel was turned almost full left. This happened when I felt in the ditch. The impact remove the tire from the rim and the rim is almost intact. Now the wheel is loose, with a play of about 1/8 around the pin bushing. I've done another 200 miles since the accident and the direction and suspention seems ok.
Here's my load of question:
- Is it king pins that I got on this van or is it ball-joints?
- Did the I-Beam took the shock and went loose or is it the bushing in it?
- Could it simply be the king pin bushing?
- If its the bushing in the I-Beam, can it be change or do I have to get a new one (or maybe get it refurbished)?
Thanks
  #2 (permalink)
Old 04-15-2004, 03:06 AM
c96drumm's Avatar
c96drumm is starting off with a positive reputation.
You have kingpins. Try tightening the kingpin retainer. It's a tapered pin with a nut on one end, runs perpendicular to the kingpin. Grease the kingpins and see if it tightens up. If not, you probably need new pins and bushings. The bushings are not in the I-beam, they're in the steering knuckle.
__________________
89 E-150 302
96 Explorer 302 AWD
00 Windstar 3.8
  #3 (permalink)
Old 04-15-2004, 08:52 AM
Changing the kingpins
Thanks for the information!
Don't you think I should go directly to changing the pins? Both of them had a small loose before my accident and they are sold by pair...
Anyway I will try tightening. If I need to replace, can I do it myself?
  #4 (permalink)
Old 04-15-2004, 12:39 PM
c96drumm's Avatar
The bushings need to be pressed in and reamed to size. I got mine done at the machine shop for 70 something bucks. The pins could be a real booger to get out, on my last one, I had to remove the axle and use heat and a hydraulic press to get it out. The one before that was pretty easy. Just have to see how it goes.
__________________
89 E-150 302
96 Explorer 302 AWD
00 Windstar 3.8
  #5 (permalink)
Old 04-15-2004, 07:13 PM
Thanks for the info.
Supposing that I can remove and replace the pins, can I go to the machine shop after with the van to get them pressed in or is it part of the installation process in wich I won't be able to use the van?
Another question: Last year I've called about 20 garages to see how much it could cost to change the pins. Some told me that I could have to get the axle hole refurbished before puting in the new pins. Is that true?
  #6 (permalink)
Old 04-15-2004, 10:51 PM
c96drumm's Avatar
You take the steering knuckles in for the bushings, so the van will be out of action.
Unless the holes are damaged for some reason, the only thing they should need is cleaning. I've done 2 of these, no hole problems.
How much did the garages say they'd charge to do this?
__________________
89 E-150 302
96 Explorer 302 AWD
00 Windstar 3.8
  #7 (permalink)
Old 04-15-2004, 11:17 PM
The only garage that gave me a price was assuming that I had ball-joints (!). The job + the parts would have been 300 CAN$ (223 US$ today).
Thanks for the info. I'll give a feedback on this, the job should be done this weekend.
  #8 (permalink)
Old 04-18-2004, 11:17 AM
Talking
Tightening and greasing did the job! Thank you so much!
No one, in all the garage that I've called, ever told me to try tightening the lock pin.
Thanks
  #9 (permalink)
Old 04-18-2004, 10:39 PM
c96drumm's Avatar
Good job!
__________________
89 E-150 302
96 Explorer 302 AWD
00 Windstar 3.8
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
