Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2004, 01:48 PM
1SG 1SG is offline
1SG is starting off with a positive reputation.
How Heavy is the Engine
I am getting ready to rebuild my motor and am looking at some engine stands. Does anyone know how heavy the 7.3 IDI is, with or without all the externals. No-Turbo. Not that the externals are that much but just too see what comes out is why I added that comment.
__________________
1990 F250 4X4 w/ ReMan Jasper 7.3, Rebuilt E4OD w/HD Shift currently in Albany NY. U.S. Army.
  #2 (permalink)
Old 04-14-2004, 03:52 PM
jadel is starting off with a positive reputation.
I'am not sure on a IDI but a psd weighs about 1000lbs.
  #3 (permalink)
Old 04-14-2004, 11:31 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
Bare complete 7.3 you are looking at about 950.
Add the alternator, power steering pump, fuel filter, fuel lift pump, oil and filter, air conditioning compressor, fan, and vacuum pump you are real close to 1100.
Turbo would put you a little over 1100.
When I pulled mine I had the freon sucked out first so I could remove the AC compressor. It is always in the way untill it is over on the floor.
I removed the vacuum pump, fan and fan clutch and alternator.
I tied the power steering pump back with the hoses still attached.
If I did it again I would also remove the crank pulley for all the belts.
In my 86 we had to almost turn the motor sideways to get the pulley to clear the top of the radiator support panel.
With a manual tranny the actual remove and install step is a three person deal to prevent damage to something else. It is a very tight fit and the motor is a little much for one person to wrestle around. The other person needs to be under the truck with the tranny/clutch detail.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #4 (permalink)
Old 04-15-2004, 04:15 PM
1SG 1SG is offline
thanx guys, and yeah dave I have pulled this one twice with 2 people. The one underneath is very important with regards to mu tranny. Making sure not too mess the TC up. Again Thanx
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
