Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2004, 12:58 PM
mustange70's Avatar
mustange70 has a good reputation on FTE. mustange70 has a good reputation on FTE.
Is 3" single better than 2.5" dual?
I just got a new exhaust installed on my pickup, i got a 3" inch pipe straight from the header into a 3" y-pipe that is located at the back of the cab, then for a muffler i got a dyno max superturbo, from there it goes over the axle and dumps behind the passenger rear tire with a 18" 3.5" tip. Now i had the option of going with a 2.5" dual system but i liked the 3" system better for the sake it was a lot cleaner underneath. Would the duals have been better?
__________________
Cody, Calgary
AB Chapter Leader
82' Flareside: 2/4 Drop, 350hp 351W, Custom interior
81' 250 mudder: home fabbed lift & dana 60 SAS , 450hp 400, 4sp/205, 38" tsl's
  #2 (permalink)
Old 04-14-2004, 06:05 PM
WhëëlMå1's Avatar
WhëëlMå1 is a splendid one to behold WhëëlMå1 is a splendid one to behold WhëëlMå1 is a splendid one to behold WhëëlMå1 is a splendid one to behold WhëëlMå1 is a splendid one to behold WhëëlMå1 is a splendid one to behold WhëëlMå1 is a splendid one to behold WhëëlMå1 is a splendid one to behold
No. The single 3" should provide the same, if not more power than the duals on a "normal" vehicles. Now, if you were running a 600hp 460, that would be a different story. The duals would be far superior to a single.
Rich
__________________
Rich
04-08 F150/Big Bronco Moderator
FTE Guidelines
Support FTE!
Support American Manufacturing!
"Made in the USA"
  #3 (permalink)
Old 04-15-2004, 09:14 PM
There Goes The Neighborhood's Avatar
There Goes The Neighborhood is starting off with a positive reputation.
A pipe with 1 inch greater diameter flows twice as much. So, if you go from dual 2.5 to a single, you'd be better off with a 3.5 for max power, 3 inch is better for TQ.
__________________
Brandon
I"m Baaaaaaaaaaack
'02 F250 PowerStroke
4" Dynomax Turbo Back
K&N FIPK(Cleaned and re-oiled every other oil change)
I don't suffer from insanity, I enjoy every minute of it.
  #4 (permalink)
Old 04-16-2004, 12:58 AM
stevef100s is new and has a neutral reputation at this point.
It sounds like you have a straight 6. Am I right? If that is so, the 3" single may be a little big. If you have a small block v-8, the 3" would provide better torques at lower rpm's, or if you carry a load or tow a lot. If you mainly drive at higher rpm's, like with highway driving and such, then duals are the way to go. With a straight six, the only way duals would be a benefit, is if you had headers with two outlets, and then I would only run 2.25" at the largest. Running a single exhaust into a Y into duals doesn't do much for anything other then the sound.
  #5 (permalink)
Old 04-16-2004, 06:14 AM
Icicle's Avatar
Icicle has a good reputation on FTE. Icicle has a good reputation on FTE. Icicle has a good reputation on FTE.
So if I get the jist of this conversation (not to hijacka thread) A small block v-8 (a 302 for example) would breathe best as a low torque truck motor with a 3" single exhaust...right?
__________________
WoW Server is down, So Im on FTE......
  #6 (permalink)
Old 04-16-2004, 10:58 AM
Correct Icicle. It's mainly about exhaust velocity. At lower rpm's, the single 3" sytem will maintain better velocity then with duals. There's also a little thermodynamics involved.
  #7 (permalink)
Old 04-16-2004, 11:24 PM
mustange70's Avatar
Thanks everyone, from what has been said it seems that i choose the right exhaust for my pickup. I just wish it was a little louder.
By the way the motor in my pickup is a 350hp 351Windsor, it's built to run in the lower rpms, and if i would have put in some slower gears (its got 3:1's) it would be able to keep up with a camero SS.
__________________
Cody, Calgary
AB Chapter Leader
  #8 (permalink)
Old 04-17-2004, 02:22 AM
DanZ is starting off with a positive reputation.
I am also interested in the sizing of the 302 single exhaust.
I have been to a few shops to price cat back systems and the most experienced guy said that 3" pipe was too big for the 5.0 and that I would lose low end torque. He said he has had people come back because they were unhappy with the 3" size and they changed to 2.5". The other shops seem to think that 3" is the way to go.
I measured my pipe dia's and found the ypipes from the manifolds to be 2.25", then it is almost 3" between the cats, and then it necks down to 2.25 after the 2nd cat and then 2.25 out from the muffler.
So I thought 3" out from the back of the 2nd cat would be best. Especially since there is a total of 4.5" in dia when you combine both pipes of the ypipe.
Now I'm a little concerned about choosing between 2.5 and 3.0". I like having torque for around town but I want h.p. when pulling my boat.
Will either of these sizes make a difference?
BTW: I plan on going with the FM 40 series muffler.
__________________
96 SC F150 4X4 5.0 5 sp, Eddie Bauer, 2 1/2" Magnaflow catback, 2" lift, 32 x 11.50 BFG AT's
91 Mustang LX 5.0 HO Too many mods to list....!
  #9 (permalink)
Old 04-17-2004, 08:59 PM
The other thing I meant to ask is whether mandrel bent pipe is really that important. For some reason all the shops I talked to have mandrel bent tubing in 3" only - not for the 2.5"
Any opinions?
__________________
  #10 (permalink)
Old 04-18-2004, 12:25 PM
dk5122 is starting off with a positive reputation.
Would the duals have been better? Now knowing you have 350hp I would have run true 2.5" duals with a crossover pipe............Your first post says header which makes it sound like a six cyl. Later
__________________
Dan's toys
76 Bronco V-8 36's
02 F-250 XLT Ext. Cab 4x4 35's
06 Mustang GT Vert
07 Escape 4x4
  #11 (permalink)
Old 04-18-2004, 12:31 PM
DanZ, you will be fine running a single 3" with your 302. My buddy has a six and runs a 3" single after the cats. He tows alot and said overall power has increased. It also sounds alot better. Get the mandrel bent pipes.
__________________
Dan's toys
76 Bronco V-8 36's
06 Mustang GT Vert
07 Escape 4x4
  #12 (permalink)
Old 04-18-2004, 10:38 PM
Thanks DK,
I was thinking 3" would be ok but that guy at the muffler shop made me wonder....
Even better since the 3" will be mandrel bent.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
