Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-13-2004, 08:26 PM
c_nate is starting off with a positive reputation.
Hard Fuel Pedal
hi all,
the old gal is having a odd problem. maybe I’m a wuus. but lately the fuel pedal has been pushing down harder than usual, but only when the engine is running. shut her down and it is no problem. This rules out a frayed actuator cable, I’d think.
also it seems the Fuel Pedal is more sensitive than normal. just barely touch it at it is off. thinking it may be an IP but , it runs well other wise. Any ideas.
167000 miles on the clock, maybe original IP, not sure since got it used at 120,000
thanks,
Nate
1994 IDI factory Turbo
4x4 3" ATS down pipe and loving it!
__________________
1994 F250 4x4
7.3 IDI factory turbo
  #2 (permalink)
Old 04-13-2004, 09:33 PM
rancherman84 is starting off with a positive reputation.
what about unhoking the throttle cable from the ip and then starting the truck to see if the throttle shaft moves hard.that will tell you if its ip or cable.but from your description,i'd say its an internal pump prob.
__________________
92 F250 HD 7.3 XLT 4X4 E40D 207,000 miles
  #3 (permalink)
Old 04-14-2004, 12:01 PM
Spectramac's Avatar
Spectramac is gaining momentum as a positive member of FTE. Spectramac is gaining momentum as a positive member of FTE.
Sounds like the pump here too.
__________________
Malcolm
97 Explorer 5.0 AWD
87 F250 6.9 CTS turbo
  #4 (permalink)
Old 04-14-2004, 02:23 PM
pnose is starting off with a positive reputation.
I had a similar prob like that,turned out it was a bad motor mount and when accelerating the engine would lift off the bad mount enough to bind the cable,might be worth checking 1st as its a pretty cheap fix.Good luck.
__________________
1992 f350 4x4.3.55 gears,E4od.8 foot
List Mod's & Extras in Gallery
FTE
  #5 (permalink)
Old 04-14-2004, 02:27 PM
Whoops had to delete a double post
__________________
FTE
  #6 (permalink)
Old 04-15-2004, 12:29 AM
thanks all,
going to check it out this weekend.
another thought was that some how the fuel pressure regulator for inside the pump is stuck and getting the wrong pressure and giving it too much fuel. (guessing here !)
was thinking back and when I first got the truck the fuel was turned up so high the pedal was overly sensitive. had to back off the fuel.
N
__________________
1994 F250 4x4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
