Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 04-13-2004, 05:41 PM
onelitreyamaha onelitreyamaha is offline
Garage is empty, add now
onelitreyamaha is starting off with a positive reputation.
converting an f150 into a lightning
i have a 99 f150 5.4 and i am buying the whole top of a brand new lightning truck engine to supercharge my engine. i will have every part of the upper intake and supercharger including the engine loom. my question is, do i have to change the fuel pump and what do i need to get the intercooler to work?
  #2 (permalink)
Old 04-13-2004, 05:44 PM
Traxxis's Avatar
Traxxis Traxxis is offline
1994 Ford Ranger
My Garage
Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.
Sorry man... but you still cannot refer to it as a "Lightning"... cause it's not unless you're gonna do all the suspension mods etc... I highly doubt that you will "need" to change the fuel pump, but it might be a good idea.
Welcome to FTE, Stan
  #3 (permalink)
Old 04-13-2004, 05:48 PM
i have a 2002 lightning truck also, i have the old suspension and rims to put on my 99! do you know what else i would have to do as far as the intercooler is concerned?
  #4 (permalink)
Old 04-13-2004, 05:57 PM
Traxxis's Avatar
1994 Ford Ranger
My Garage
uh... well, prolly your best bet is gonna be to post in the Lightning forum, they can help you much more than I can, however I believe that the intercooler should be fairly easy... just mount it and plumb it. I think this will prolly be the least of your problems though, I think the tough part will be the s/c itself. Also, the brakes are different on the Lightning too, they are actually 3/4 ton brakes. That's a project, but good luck.
J/C Why are you tearing through a 02 Lightning to make a 99?
  #5 (permalink)
Old 04-14-2004, 01:00 PM
nicholsd nicholsd is offline
nicholsd is starting off with a positive reputation.
I don't know if that will work but go to....Madenterprise.com..........he can answer all of your questions and sell you all the parts needed to get your truck running. Good luck
  #6 (permalink)
Old 04-14-2004, 08:06 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Why not go with a 5.4 supercharger instead of a "lightning" supercharger. Probably cheaper and the kit will have all the parts you need to install.
__________________
Justin
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
  #7 (permalink)
Old 04-24-2004, 03:09 AM
Madferraristi's Avatar
Madferraristi Madferraristi is offline
Madferraristi is starting off with a positive reputation.
Everything you will need at http://www.madenterprise.com/f150.htm
  #8 (permalink)
Old 06-02-2004, 10:31 PM
CJack CJack is offline
CJack is starting off with a positive reputation.
Dont get the OEM supercharger, get your own internals and build an engine, then put a Kenne Bell supercharger on it, at 14 pounds of boost or so. Then go out and try to hold traction.
__________________
2003 Crew Cab Short Bed F250 XLT 5.4L
  #9 (permalink)
Old 06-08-2004, 11:59 AM
low92flareside low92flareside is offline
low92flareside is starting off with a positive reputation.
Probably better off buying aftermarket. The stock supercharger has a habit of overheating after a few 1/4 mile runs and performance is affected greatly.
Tags
2004, 54l, convert, converting, f150, ford, lighting, lightning, make, making, motor, putting, regular, stock, supercharger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
