Steering Column
Steering Column
I am thinking of changing my existing steering column to a tilt column. Need extra room for more beer. What is involved and what brand of column is easist to adapt to existing steering box. Also i would like to add power steering at the same time. Any suggestions. About how much would all this cost?
Terry
Terry
on
the whole nine yards
Ididit chrome tilt column with cruise built in......... $ 800
removing the Volare IFS you shouldn't have used...?????
heidt's Mustang II IFS with power rack............... $2200
steering wheel of your choice............................ $ 300
assorted u-joints and shafts to connect.............. $ 250
but that's only one route you can take....
seriously.. you can find a salvage yard tilt unit from 50 bucks and up
if it's not worn out...
power steering ??? you staying with the straight axle or going ifs ???
price range is wide
are you going to shift on the column or from the floor ???
ford van units work well.... mid 80's chevy sedan columns work and are about the right length...
lots of questions need to be answered before a good decision can be made here..
later
john
price range is wide
later
john
on
Originally Posted by 55forder
John, my feelers get all twisted up when you talk bad about Volare front ends. And here I was thinking I was doing such a good job on my truck.
55forder
55forder
Don't pay any attention to John. Next month he will want a Dakota... Just keep plugging along on your Volare. It's lookin' good...
Vern
tlb
My 51 has a caddy tilt, between that the seville seat and the tank behind the seat......I had to cut out beer . I am changing to an Ididit column, late model Expedition seats and the tank is going under the bed. That way I can include beer back into my diet
Seriously, if you have a thinner seat that I do about any of the tilts will work, the van is a good choice or some of the gm columns. One thing to keep in mind if you are rewiring is most wiring kits are set for gm columns. I am changing to the Ididit column because I want to go keyless and mine needs the turn signal switch rebuilt and to do that the parts are almost 1/2 of the cost of a new column.
on
from the negative post on the dark side.....
guys...guys...guys...
I never said Volare was bad.... I just said it was a bad choice for me ! I've ridden and driven Volare equiped trucks and they are great riding... I would have left mine in...but I wanted to steer and have cool looking headers
Bent bar boys have faith.... keep on your path and you will be rewarded with a smooth ride and infinite adjustability... a great reward for such a ugly ifs
later
john
later
john
on
john
john
I have to agree with Bill. You certainly do not want to wire your truck and then change the column later if you can avoid it. The column is the center point for the wiring system.
Vern
Just as a practical matter I would do the whole rewire as step 1. Then after you try the lights, blinkers, etc and are satisfied that you did everything correctly, put in the column as step 2. Otherwise, what if you do it all as one process and something doesn't work right. Is it the new wiring or is it the new column? This scenerio would be much harder to diagnose. Just my 2 cents worth. John
on
Originally Posted by tlb
Thanks Guys
I am trying to set priorities by need and money. The re-wire is a necessity. To many wires going who knows were. I would like to both at same time but don't know if i can.
Doing a complete brake job now. If you can't whoa then you should't go.
Terry
Terry
Vern
