Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-13-2004, 05:28 PM
wycowboy's Avatar
wycowboy is starting off with a positive reputation.
Talking Cavatation, Why??
can any one explain to me why cavatation is only a problem in diesels, and not gas.. I understand what it is, but why dose it only happens to diesel's. . Just trying to broaden my knowledge base,J.
__________________
97 F250 PSD, sc, 4x4 5sp, 3.55. 150K miles, 6637, Amsoil 5-40w/ bypass, SCTM, auto meter, Napa Coolant fliter. 203*t-stat,
  #2 (permalink)
Old 04-13-2004, 09:00 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
No gasoline motor that I am aware of can stand 22.5 to 1 compression and add 15 pounds of turbo boost on top of that.
But diesels have that or more.
The main reason is the compression pressures and the combustion pressures cause vibration in the cylinder walls.
This vibration is what causes the air bubbles to form.
The 7.3 block basicly is a bored 6.9 block which makes the walls thinner, this causes the vibration to be stronger and the corossion has less distance to eat through.
"Most" diesel motor manufacturers either require an addative or antifreeze that already has the addative properties in it.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #3 (permalink)
Old 04-14-2004, 12:05 AM
Spectramac's Avatar
Spectramac is gaining momentum as a positive member of FTE. Spectramac is gaining momentum as a positive member of FTE.
Cavitation has been a problem with the big diesels as well. Cummins tried a low flow cooling system years ago on the big rigs to try and keep air bubbles to a minimum. They used small hoses like heater hoses to run the coolant to and from the radiator. It must not have helped much, I don't see them much any more.
__________________
Malcolm
97 Explorer 5.0 AWD
87 F250 6.9 CTS turbo
  #4 (permalink)
Old 04-14-2004, 01:12 AM
wycowboy's Avatar
Thanks,That makes sence. J
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
