don't hold me to this but,
The dana 60 were used in the the early 80's models. 85 and down. the 10.25 was 85~86 and up. as for a swap, they SHOULD (key word sholud) swap, but you will have to check for spring perch placements and width of axle. Since they are both 250's and the rears were just different, I don't see why it would not work. Get all your measurements and check for likeness in both axles before you undo anything, good luck
__________________
---Fire Prevention is Everyone's Business--
