I'm right here Bilder. This is a tough one to do by message board. Is that a new piston you put in there or a used one? I would say the injector was the problem, but not after you tried 3 of them. Sounds like piston slap or the rod bearing is loose. You say there was .003" taper, but what's the piston clearance? Sorry, no miracle cure here, but I'll be thinking about it all day at work.
