1997 f150 shift cable problem - Ford Truck Enthusiasts Forums
Old 04-12-2004, 07:52 PM
FUBARHUBAR FUBARHUBAR is offline
FUBARHUBAR is starting off with a positive reputation.
Question 1997 f150 shift cable problem
1997 f150 4.6 auto 4X4. shift cable seems to have streched(wont go into park all the way). is there an adjustment or is it replace only?
Old 04-12-2004, 08:40 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
First look it over real good. Ive seen the bolts come loose on the shift cable bracket at the end of the steering columb, shift lever tube broken, shift lever bushings worn out, shift cable braket loose at transmission. Ensure everything is tight before condeming the cable.
Old 04-12-2004, 11:54 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi FUBARHUBAR and welcome to the forum
Homer mentioned the common problems that should definately be looked at first but yes there is an adjustment on the cable. Where the cable attaches to the lever on the transmission there is a lock tab that you push up, then you slide the cable in or out as needed and push the lock tab back down.
These cables dont seem to usually have problems though. If I had to bet, I'd say that the cable bracket on the end of the column , like Homer mentioned, is loose.
Old 07-28-2015, 05:40 PM
Tim Armour Tim Armour is offline
Tim Armour is starting off with a positive reputation.
How do you push up lock tab?
How you push up lock tab without breaking it?
2004 F150 Shift Cable Repair Bushing motolorenzo 2004 - 2008 F150 5 03-21-2016 10:26 AM
Shift cable linkage to transmission samf1 2004 - 2008 F150 10 09-27-2015 11:59 AM
!Resolved! - No Crank no start 97 F150 5.4l 4x4 Auto iamvandemon 1997 - 2003 F150 10 03-17-2015 05:09 PM
Shift cable removal wtroger 1999 to 2016 Super Duty 2 03-25-2011 09:38 PM
Shift Indicator cable blueovalboy86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-07-2005 09:18 AM
Tags
07, 1997, 1998, 1999, 2006, adjustment, cable, f150, ford, issues, loose, shift, shifter, shifting, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
