Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-12-2004, 08:06 PM
jstew99x is starting off with a positive reputation.
Help. RPMS GO up X does not go
2000 5.4 x 95k miles.
While on a trip when trying to accellerate, my rpms go up and then I back out it and it will go.
Changed fuel filter, cleaned injectors. I have checked trans fluid. Has anyone else had this prblem and what corrected it.
Thanks
Stu
  #2 (permalink)
Old 04-12-2004, 11:34 PM
Beachbumcook's Avatar
Got Diesel?
Beachbumcook has a good reputation on FTE. Beachbumcook has a good reputation on FTE. Beachbumcook has a good reputation on FTE.
Sounds like a classic "transmission is slipping" issue.
Are you using the right trype or regular tranny fluid as required?
Are you using synthetic tranny fluid? Some tranny's find synthetic too slippery to operate properly.
I would take to a transmission shop or dealer and have a free inspection from 2 or 3 places and get a better idea of what is going on.
Good luck,
Jeff
__________________
03 Excursion 6.0L PSD
Magnafine P/S Fluid Filter
Racor By-Pass Oil Filter System
Dieselsite Coolant Filter
Bilstein Shocks/Rancho Steering Stabilizer
Fumoto Oil Drain Valve
BriteBox Headlight Module
Marinco AC Block Heater Plug
24" Wiper Blades
Window Screen - Radiator Bug Shield
Pioneer Airware XM Radio
  #3 (permalink)
Old 04-14-2004, 06:18 PM
bigslurrp's Avatar
bigslurrp is starting off with a positive reputation.
Was this in all gears? I talked to a transmission tech at Transgo performance and he said the early 2000 4R100's are notorious for some second gear thingy coming apart. It would only rev and go nowhere but eventually it would slip into third. He told me if that ever happened to not rev the engine and get to a shop asap. It wouldn't require a total rebuild.
__________________
- Ken
2000 F350 Super Duty 4X4 Crew Cab Lariat LB
Tri-pillar with Autometer Guages, DP Tuner, ATS Ported Compressor Housing, Wicked Wheel, EBPV-less flange, 4" Downdpipe, 5" Exhaust, 6" Tip, 285's
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
