Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-12-2004, 07:34 PM
ninelives 59 is starting off with a positive reputation.
diesel fumes in cab
I have a 2003 F350 p/s and have fumes from the exhaust in cab with the ac on and off.The problem is not too major for me but my wife will not ride in the truck no more and says that she will not have our kids in the truck unless this is fixed.The major stink of this is that her father owns a 2002 diesel and does not have this problem.The last time the truck was at the dealer I had them check under the hood for any leaks and they found nothing. I bought a battery powered carbon detector tonight and I will try it out on the way to work. My question is that should I contact a ford rep about and file the the papers to buy the thing back?
  #2 (permalink)
Old 04-12-2004, 10:00 PM
Fordtech1's Avatar
Fordtech1 is starting off with a positive reputation.
Is your truck equipped with the 6.0 Powerstroke? Is her father's a 7.3? If so, then your fumes could be coming from the tube directly behind the turbo. It has a flexible mesh section that has been known to cause problems on the 2003 - 2004 6.0L, but no such tube is on the 7.3L, completely different systems, and no mesh.
  #3 (permalink)
Old 04-13-2004, 10:09 AM
Truck is the 6.0 and the fathers is a 7.3.If there is a flex hose behind the turbo I will check it out. thanks
  #4 (permalink)
Old 04-14-2004, 06:55 AM
04superduty is starting off with a positive reputation.
I have the same problem. No mater what i do there is a nasty exhaust stink in my cab. When i first get moving i have to open the windows to air out my cab. With it being about 25 today, its not fun.
__________________
04 F-350 PSD, Super Cab, Short Box. 9' 2" Boss V-blade. 72 Bronco getting rebuilt.
  #5 (permalink)
Old 04-14-2004, 09:16 AM
What are you going to do about this?
  #6 (permalink)
Old 04-14-2004, 05:56 PM
jorzac is starting off with a positive reputation.
Have the flex tube on the backside of the turbo checked. I complained about mine for 6 months. I took a copy of a thread from this web site that mentioned this flex tube. You got it, thats what they checked and indeed it was cracked. NO MORE FUMES for now. They have no update for it so it could fail again.
  #7 (permalink)
Old 04-14-2004, 08:01 PM
I will take in into ford next week and have it checked out.thanks for all the help everyone.
  #8 (permalink)
Old 04-15-2004, 11:04 PM
softwizard is starting off with a positive reputation.
Did you guys also hear a hiss? I started hearing a hiss on the drivers side mostly coming from the bottom of the truck last week and started smelling exhaust fumes in the cab and on the left side of the engine.
__________________
Kevin
2004 F-350 CC DRW LB Loaded
  #9 (permalink)
Old 04-15-2004, 11:28 PM
Fordtech1's Avatar
Get out your flashlight and check the FIREWALL area behind the turbo downtubes for any black powdery residue that would indicate a leak. Leaks in this area can cause fumes and noises. A sharp whistling noise may be the stainless steel gasket at the downtube connection on the passenger side.
__________________
02 King Ranch
It's all easy when you know how!
  #10 (permalink)
Old 04-16-2004, 08:27 AM
04-HD4U2NV is starting off with a positive reputation.
I have noticed it in the garage - does it smell kind of like burnt rubber? Then yesterday I had the vent on and the cab smelled the same. I picked up my wife and she said it smelled like a skunk in the cab, again it was kind of the same burnt rubber smell and I could smell it before she got in so I turned the controls to off and it went away. Never noticed it as much when the heater/defroster was being used but once in a while for a short period of time I could. No I haven't been turning the tires! Always been a Ford guy and sometimes I think these threads are inconsiderate of new products but since having the transmission worked on - the dealer getting something on the hood and buffing it out (looks like crap) and now the cab fumes, maybe some have legitimate bitches. I'm only in the first 500 miles on an 04/04 late January build and this is my first real diesel except my then new 1980 toyota pickup 4 banger that let a wrist pin go early in life.
  #11 (permalink)
Old 04-16-2004, 08:51 AM
BossEliminator is starting off with a positive reputation.
same smell
I have 2,000 miles on my 04 and just started getting the skunk smell in the cab. Is the flex tube the only thing that can cause this? Is there a service bulliten out on this problem. The smell was really bad last night and the kids and wife were complaining. Only problem I've had with the truck so far and last night was the first time it became a real concern.
Brian
04 XLT 4X4 SC PSD
  #12 (permalink)
Old 04-16-2004, 07:53 PM
Fordtech1's Avatar
Running over a skunk may also cause this concern.....check the firewall for soot!!
__________________
02 King Ranch
  #13 (permalink)
Old 05-05-2004, 03:17 PM
utahtom's Avatar
utahtom is gaining momentum as a positive member of FTE. utahtom is gaining momentum as a positive member of FTE.
diesel fumes in cab
I had the hiss on drivers side of engine and fumes in the cab- The dealer found the exhaust manifold leaked at the gasket. Problem solved
  #14 (permalink)
Old 05-05-2004, 03:29 PM
deacjrt's Avatar
deacjrt is starting off with a positive reputation.
I had the skunk smell also for about the first 500 miles, it only smelled in the garage and it has since went away (1600 miles). As for diesel smell in the cab, I remember other posts that reiterated what UtahTom said, it turned out to be a leaky manifold.
__________________
F-250 CC Fx4 Lariat PSD 6-Speed with moonroof, camper package and AIC. Medium Wedgewood Blue over Arizona Beige. Retrax bed cover. Cabelas Trail Gear floor mats. Edge Juice Platinum with Attitude. Airaid Intake. MBRP exhaust.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
