Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-12-2004, 06:55 PM
DMAN is starting off with a positive reputation.
85 f-350
My dad has an 85 f-350 diesel that were converting to a dump truck. The ? I have is its a single wheel can we just put a set of duelly rims on it or do we need spacers? I know it will work on some rear ends but I'am not sure how to tell if it will work.
  #2 (permalink)
Old 04-13-2004, 12:03 AM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
Did the truck come from the factory as a cab and chassis or with a pickup box?
The cab and chassis has a 34" frame and you can install dual bud wheels.
The one with a pickup box installed had a 37.5" frame. You can not install dual wheels on this truck without either spacers, not a good idea for heavy loads, or get the rear axle out of a factory dually and install it.
You can swap the gears out of your rear and use the dually axles. I had a salvage yard here offer to swap me housings for 400 dollars.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #3 (permalink)
Old 04-13-2004, 08:33 AM
FireMarshal3311 is starting off with a positive reputation.
Same boat
Hey, I am in the same boat as you are. I have had this conversation many times with the guys here on this forum. I have gotten quotes from 600 for a housing to 1800 for a complete swap. If you can find one good luck. I currently run spacers on mine just because it was that way when I bought it. I have only pulled a skidloader with it a couple of times with no problems, However, exactly as Dave said, don't use them for heavy loads. They cause a lot of problems, from bearing wear to breaking lugs off. As soon as I find a good axle I can afford I am swaping. So good luck onl your swap.
__________________
---Fire Prevention is Everyone's Business--
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
