Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-12-2004, 05:26 PM
5356f100 5356f100 is offline
Garage is empty, add now
5356f100 is starting off with a positive reputation.
help identify mark
A friend of mine has given me a 239 to use. But I was checking the numbers and before the identifying marks of A13M there is a 64 in a circle. Is this some sort of mark to show it was rebuilt? And if so would that designate the year it was done or identify the mechanic or shop? Thanks
__________________
ron
  #2 (permalink)
Old 04-12-2004, 07:53 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Try this website
http://flatheaddrag.com/birthday.html
If I'm reading the chart right I'd say April 13, 1950
If it's a factory rebuild it should have a tag indicating bearing sizes, who, when, etc. Usually when rebuilt they grind off the original build stamping - I'd guess the one you have is stock or done locally if rebuilt.
The 64 in the circle is probably just an inspector number - otherwise unknown.
  #3 (permalink)
Old 04-13-2004, 02:35 AM
You have the date on the block correct. I was curious about the 64 as this I haven't seen before. But I could have sworn I read something about this type of mark but can't remember, drain bamage from a mis-spent youth. I have a chance to pick up two more flatheads, one is possibly a merc. And thanks for the reply.
__________________
ron
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
