351 EFI Performance - Ford Truck Enthusiasts Forums
351 EFI Performance
Old 04-12-2004, 05:42 PM
Fordication's Avatar
Fordication Fordication is offline
Fordication is new and has a neutral reputation at this point.
351 EFI Performance
OK, I have done several searches and all come up empty so here goes. Lets say I want to buy a used 351 out of a 93 F-150. I will be getting a AOD transmission and as the book says I will not be getting a roller cam engine. Lets also say that I am having it rebuilt and I do want an all around good low maintenance but powerfull motor. What should I have done to the motor for good horsepower and a compromise but realiability and good gas mileage. Ed
Old 04-12-2004, 08:03 PM
LoosMaster's Avatar
LoosMaster LoosMaster is offline
LoosMaster is starting off with a positive reputation.
Bigger ? What do you plan to do with the engine? Truck, car, towing, slinging mud, jumping ditches or just a daily driver with some ummph.
Old 10-01-2011, 02:44 AM
FloridaCrackerJack FloridaCrackerJack is offline
FloridaCrackerJack is starting off with a positive reputation.
I am also wanting to put a racing cam in my 1991 351w. can i keep the rest stock the ingnition system has plenty of spark. the efi works great. i am also wanting to install headers and a mallory unilight dist. what do you guys think?
my question is how much can i get away with with out having to do a holley retro efi. i want to get the most power i can and keep the stock intake look
1991
f 150 2wd auto transmission.
do i have a c6? my tranny code is E
thanks
Old 10-01-2011, 01:01 PM
Terpfords's Avatar
Terpfords Terpfords is offline
Terpfords is starting off with a positive reputation.
The formula for performance upgrades is about the same for a 302/351 in a truck with the stock intake. There is plenty of performance within the stock drive train parameters.There are quite a few people who have done it and there is always lively discussion on the 87-96 boards.
A good stock rebuild with attention to detail can produce excellent results. A little more compression, mild speed density cam accompanied by some good bolt ons will do well.
As far a the engine rebuild itself. I would suggest the first step is to find a machine shop to deal with. Without telling the Machinist what to do, I would get a light flattop piston, calculate the increase in compression to bring it upwards of 9/1 but not over 10, larger valves and almost any mild speed density compatible cam will be a big improvement.
New Guy KWEEKS 6.7L Power Stroke Diesel 17 04-30-2012 08:50 PM
Engine Build Questions, Extra Block? Aaron-71 1973 - 1979 F-100 & Larger F-Series Trucks 14 05-03-2011 11:50 PM
351M to 351W EFI in 78 bronco hd78bronco Engine Swaps 4 10-15-2010 10:43 AM
letting a stroked 351w to 408 breath smallblock351w Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 72 07-15-2007 09:43 AM
300 six to 351W swap....getting desperate HotWhlz85 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 14 06-01-2002 10:38 AM
Tags
289, 351, 351efi, 351w, 58, camshaft, distributor, efi, engine, f150, ford, fuel, injection, performance, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
