no start just clicks........ - Ford Truck Enthusiasts Forums
Old 04-12-2004, 04:31 PM
wallysparks wallysparks is offline
wallysparks is starting off with a positive reputation.
I got a 1989 ranger 2.3 ltr. and when I put the key in everything works but as soon as I try to start it everything goes out and solenoid just clicks then 30 sec. later it kicks back on but it still won't start it just does the samething over and over anyone?
Old 04-12-2004, 07:07 PM
Quackhead94ranger Quackhead94ranger is offline
Quackhead94ranger is starting off with a positive reputation.
did u check your battery? hows the alternator?
quack
Old 04-12-2004, 09:43 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Post
Welcome to FTE.
Begin with the battery connections. Take them apart and clean them up. When you put them back together, check to make sure that all connections are properly tightened.
Check/charge the battery. Boost if needed.
Old 04-13-2004, 12:31 PM
andyrew andyrew is offline
andyrew is starting off with a positive reputation.
also check connections at starter, try spraying wd-40 on them
Old 04-15-2004, 03:59 PM
fords8's Avatar
fords8 fords8 is offline
fords8 is gaining momentum as a positive member of FTE.
Also check the ground wire from the battery. Follow it down and make sure the other side of it is tight. It should goto the block somewhere. Maybe to the inner fender.
Old 04-25-2004, 09:07 AM
parproboy parproboy is offline
parproboy is starting off with a positive reputation.
Question Does fuel pump run?
I agree with all the above checks as far as the cable connections. One other thing I might add. Maybe it will help. When you turn the key does your fuel pump run? You should hear 2 "clicks" from the passenger side as well. The reason I ask the question is there are at least 3 relays located just under the main fuse box on the passenger side of the fender near the air cleaner box. I had a related problem with a 87BII. It drove me nuts. (short drive for me) I installed new batt. cables and the starter solinoid as well. After doing all that a friend came over with his ranger and when he started his up I could hear all the 'clicks' from his relays and discoverd my problem. Right place, right time deal.
Old 05-03-2004, 02:50 PM
CMazz CMazz is offline
CMazz is starting off with a positive reputation.
Do u have a good ground? That's where I would check sounds like a short somewhere to me.
Chris
Old 03-26-2007, 02:00 PM
bryrykim bryrykim is offline
bryrykim is starting off with a positive reputation.
also check the sylanoid maybe it needs replaced you could try jumping the starter and or sylanoid to do this on the sylanoid you need to unplug the little red wire and take a flat head screwdriver jump it to one of the other teminals on the sylanoid and on the starter you just jump the two terminals
Old 04-28-2007, 10:19 PM
broke77f100 broke77f100 is offline
broke77f100 is starting off with a positive reputation.
Yeah, definitely check the solenoid. All of the fords at my house(my 77 F100, my dads 86 F150, my brother's 87 BII, my 88 Ranger) have all had a small bit of trouble from the solenoid. The first one to go bad was the Ranger's. I noticed it clicked sometimes and i would have to shut the key off and try again to start it. That was obviously a sign that it was going bad. After that it would just click and not start. I replaced it with the one from my 77 F100 because i had a brand new one in my 77 F100 even though the truck wasnt running yet. Then the F150's went bad so i replaced it with the brand new one(for 77 model) and it worked fine. I guess my brother's 87 BII doesn't need one just yet but it probably will.
Old 04-30-2007, 12:59 AM
TLyttle TLyttle is offline
TLyttle is starting off with a positive reputation.
I started using dielectric grease on all battery connections years ago, and haven't had any problem since. The grease keeps out corrosion, and assures proper connections all the time.
Use it on the terminals, the ground connections, and the solonoid connections. As much as it sounds "wrong" to put grease on a connector, this stuff works as advertised.
Single click on starter Scott Rabb 1978 - 1996 Big Bronco 3 01-15-2016 11:24 AM
99 f350 Clicking r1819m 1999 to 2016 Super Duty 5 12-09-2015 08:06 AM
GLOW PLUG RELAY CLICKS ONCE....NO START liquidlounge 1999 - 2003 7.3L Power Stroke Diesel 6 12-03-2014 05:39 AM
Explorer Rattling Under the Dashboard jamelton Explorer, Sport Trac, Mountaineer & Aviator 1 11-20-2014 08:30 PM
Click...click...click reflections 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 07-01-2009 02:55 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1988, 1994, 94, click, clicks, f150, ford, problem, ranger, red, solinoid, start, starter, starting, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
