Need instructions for superunner steering kit
Hi.
Would someone please be so kind to email me or fax me the superunner install instructions for my 96 bronco? I bought the kit used and don't have the instructions. Also can someone tell me the differance between Rancho's drop down pitman arm and superlifts pitman arm, I'm trying to figure out why you have to use superlifts pitman arm.
thanks for the help.
You should contact the company. I see no reason why they would not be able to fax or email you a copy of the exact instructions you need. http://www.superlift.com
Rich
Rich
Originally Posted by marriedguy1
I used my old drop pitman arm with my superlift steering and have had no ill effects. I had Pro-Comp bracketry and replaced it with the superlift brakcets and then re-used the old pitman arm. I have 6 inches of lift and it aligned and drives fine.
thanks
OK let me clarify:
I had a Pro-Comp lift with a drop pitman arm. I don't kow who made the pitman arm, it came in the kit. I can only assume that it is a Pro Comp and not a superlift.
The brackets cost me about 70 bucks each thru 4 wheel parts. You have to special order them. I got their part numbers off the superlift web site and then went into the 4 wheel parts store and had them look the numbers up and order them.
I had to use the superlift brackets to get the superrunner steering kit to bolt on. The superlift brakcets have an attachment point for the idler arm that the pro-comp brackets do not. You could prolly fab up the necessary bracket and weld it on to the pro-comp brakcet, but I did not feel comfortable doing that.
Bryanblaylock
03-12-2018 10:48 AM
SnuffthePunkz
15
11-28-2011 12:07 AM
