Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-11-2004, 05:06 PM
swunderle is starting off with a positive reputation.
in N but says R
I have an 2001 XLT V6. This problem seems to be getting worse. Trans selector says it is in reverse but car in in N. press gas motor just revs and you don't move. Is this just an adjustment i can do Or more complicated? Help please. Common problem?
  #2 (permalink)
Old 04-11-2004, 05:40 PM
stepman is starting off with a positive reputation.
If you look under the steering column, you should see a small plastic cable with a little wheel on it. It's attached to the column by one screw( white plastic piece). Turn the wheel and it will move the indicater. Problem with them is that with all that plastic the "ears like to break off. Sometimes they can be repaired with a zip-tie.
__________________
53 F250
I used to couldn't spell mecanic, now I are won.
  #3 (permalink)
Old 04-13-2004, 09:21 PM
bananaboat is starting off with a positive reputation.
If stepman's solution doesn't work and it won't go in ANY selection, you may have lost your tranny. The CD4E tranny in the 2001 and early 2002s seem to be more likely to have tranny problems. This goes back to the Mazda 626 using the tranny in the 90's too.
  #4 (permalink)
Old 04-16-2004, 10:28 AM
I think I may have read that wrong. I was thinking it was just an indicater problem but, it may be something else. If that's the case, I would start by checking the fluid.
__________________
53 F250
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
