1989 F350 wiring diagram - Ford Truck Enthusiasts Forums
Old 04-11-2004, 12:10 PM
RalphBeyer RalphBeyer is offline
RalphBeyer is starting off with a positive reputation.
Unhappy 1989 F350 wiring diagram
I am experiencing a problem with my blinkers and emergency flashers. They worked up until I turned on the flashers and then quit working. I checked fuses and power coming from panel and it checks good. This happened before about a year ago and they started working again but about a week ago after using the flashers it started again. I am lost as to what I can do and can't find a wiring diagram for my 1989 F350, so I can trace the problem and maybe bypass it. I hope someone can help me. Thanks in advance
Old 04-11-2004, 02:24 PM
carpe_diem carpe_diem is offline
carpe_diem is starting off with a positive reputation.
There are often wiring manuals on ebay...
I commiserate, the electrical problems IMO are the most frustrating.
Emergency/TurnSignal Flasher hdunlap 1967 - 1972 F-100 & Larger F-Series Trucks 16 11-19-2016 02:36 PM
HOWTO - Add LED Lights Luke76 '80-'86 HOWTO's 70 03-28-2016 08:09 PM
6.0 solution now no start Tylor Reynolds 6.0L Power Stroke Diesel 17 04-25-2014 09:59 PM
Rear turn flasher brake light problem tiopet 1968-2013 Full Size Vans 5 04-12-2013 02:14 AM
No Brake lights or Emergency Flasher dakonthemountain 1973 - 1979 F-100 & Larger F-Series Trucks 13 11-26-2005 10:13 AM
Tags
1987, 1989, 1989f350, 87, 89, alternator, diagram, diagrams, engine, f150, f350, ford, fuse, radio, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
