Dull headlight lenes
If someone has this problem, this is what I did.
I bought a polishing pad and bonnet for my drill and some plastic polish. Total cost around $10. Place some polish on the pad and gently work it onto the headlight lens. Start with a some what firm pressure and as the polishing compound thins out lighten up the pressure to finish polishing. Watch out for the casting nibs, you don't want to catch them and break your headlight lens. It takes about 10 to 15 minutes per side, be sure to touchup the marker lights too. Then give your vehicle a good cleaning to remove compound residue. Then a coat of wax can be applied to the lenes for protection.
Did it to my son's T-bird worked great.
I've polished the headlight lenses on my wife's Aerostar a couple of times using Meguiar's Plast-X polish. It works great. I did it by hand (wax on - wax off) in about 2 minutes per lens. Of course, I wasn't looking to restore showroom appearance - just to get some dang light through the foggy yellow plastic. It makes a huge difference & seems to be good for about 6 months at a time.
Cheers,
Eric
Cheers,
Eric
AeroShell makes a product called "Flight Jacket Plexicoat" that's great for all Plexiglass windows and plastic lens type applications. It's made for aircraft applications, but also does a very nice job on auto lenses. Look for it at the pilotshop at your local airport, or do a search here on the internet. I've found it for as little as $7.50, and as much as $15 for a 16 oz bottle. It's fast, it protects from UV rays, and it last.
