Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-11-2004, 06:57 AM
jarl is starting off with a positive reputation.
What kind of engine ?
Need a new engine for my 93 E-150.
The old one is a 302 w/AOD.
Could I replace it with a 4.6L or maybe a 5.8 ??
Thanks
Jarl
  #2 (permalink)
Old 04-11-2004, 06:59 AM
68torino's Avatar
68torino is starting off with a positive reputation.
5.8 would be the easier of the two.
__________________
Duane
68torino
1989 F250HD XLT LARIAT 351 ZF5 sp 4X4
1991 Aerostar E4WD XLT
1992 Crown Vic ex. fed car
  #3 (permalink)
Old 04-11-2004, 09:52 AM
jpsartre12 is starting off with a positive reputation.
Thanks
Jarl
I have a 302 in my 91 Club Wagon. If it goes, I'd drop a 351 in its place.
__________________
Bumper sticker of the year:
"If you can read this, thank a teacher....and since it's in English, thank a soldier
1991 Club Wagon XLT - Tow Vehicle
  #4 (permalink)
Old 04-11-2004, 02:48 PM
Yakk is starting off with a positive reputation.
I think that's a worthwhile swap considering--
You can go with a 5.8 if:
You're shift pattern is P-R-N-OD-D-1(the hydraulc AOD)
It may run OK with the 5.0 computer, but don't bank on it.
You'll need the 5.8 computer from a truck/van that had a 5.8 with C6 auto.(Good luck.)
87-88 would be the best years to find this computer since most 89-later 5.8 were ahead of E4OD's.
The EFI 5.8s never had AOD or AODE behind them only C6 or E4OD.
Your wiring harness should work with the 5.8 and computer, although the 5.8 doesn't need the knock sensor or power steering pressure switch.
You're best bet for the engine, is to get a complete unit since the intake and exhaust manifolds are different. The accessory mounting brackets are different although you can use your old accessories.
Here's the deal on the '93 AOD.
Quote:
Originally Posted by Baumann Engineering Website
1992-93 E and F series trucks (those with AOD’s and not E4OD’s) contain the strongest production AOD transmissions.
-J-R-
__________________
"Why would Ford put a six in that beast?"
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
