Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-10-2004, 11:22 PM
mustange70's Avatar
mustange70 has a good reputation on FTE. mustange70 has a good reputation on FTE.
Whan can I expect for 1/4 times?
I would like to know what kind of 1/4 mile times i can expect for my truck, it has a 350hp 351w, with a toploader wide ratio 4-sp, currently it has 3:1 gears (if would also like to know the times for 3:5:1, and 4.3:1 gears to if possible), and no locker and it ways about 3650lbs.
__________________
Cody, Calgary
AB Chapter Leader
82' Flareside: 2/4 Drop, 350hp 351W, Custom interior
81' 250 mudder: home fabbed lift & dana 60 SAS , 450hp 400, 4sp/205, 38" tsl's
  #2 (permalink)
Old 04-11-2004, 01:00 AM
Ratsmoker's Avatar
Ratsmoker is starting off with a positive reputation.
Mid to low 15s are likely IMHO.
  #3 (permalink)
Old 04-11-2004, 01:25 AM
DW2455's Avatar
DW2455 is starting off with a positive reputation.
I dont think it would hook off the line very well if he steped up the gears so i'd be surprised if did better than 16's DW
__________________
MY Web site have A L@@K
  #4 (permalink)
Old 04-11-2004, 11:50 AM
Ratsmoker's Avatar
Here is a couple videos of my truck taking off. http://www.clubfte.com/users/ratsmoker/Truck.zip (right click and "save as")
In one video I held the brake but in the other I didn't. I just stomped it. I can hook up much better if I go easy on the gas. My truck runs mid 14s.
These trucks can hook up fairly decent with some good tires and traction bars. My 60 foot times on skinnier tires was a consistent 2.2 seconds. I think I can get solid 2.1s on the tires I have now.
BTW, I have 3.70 gears and a 3,200 stall.
  #5 (permalink)
Old 04-11-2004, 07:01 PM
94F150-408 is starting off with a positive reputation.
Dang Ratsmoker, thats a tall stall. Any tranny temp issues with that?
mustange70, I would say high 15's if you hook up OK with your current combo.
__________________
94 F150 4x4 393 Stroker
95 Bronco- 408 SuperCharged
Mods in Gallery
  #6 (permalink)
Old 04-11-2004, 07:25 PM
Ratsmoker's Avatar
Oh yeah, if I were to run without a tranny cooler I would be doing a rebuild every time I went to the dragstrip. It used to make the floorboard almost too hot to touch just cruising around without getting on it. I used the AC condenser and converted it to a tranny cooler. Now I can go rip on it and the floorboard is cool to the touch. BIG DIFFERENCE!!!
  #7 (permalink)
Old 04-12-2004, 01:09 AM
mustange70's Avatar
thanks guys. I'm also thinking of building an extra 9" diff that has 4.30's and a spool for the track ( with someones help i can change the 3rd member in 10-20mins) and if i did do this i would buy some traction bars from summit, with this set up in place what should i be expecting?
__________________
Cody, Calgary
AB Chapter Leader
  #8 (permalink)
Old 04-12-2004, 01:25 AM
fordeverpower's Avatar
fordeverpower is starting off with a positive reputation.
i agree with the fact that it should run in the mid 15's.
__________________
Matt
79 f150 390 4x4 c6 RIP
78 F100 390 2wd c6
78 F150 351m 4x4 c6
  #9 (permalink)
Old 04-13-2004, 12:28 AM
mustange70's Avatar
thanks guys. Now that i've driven the truck i going to put in 3.50's because the 3:1's chatters the clutch (vibrates the truck all to hell too) real bad because of the high 1st gear in the tranny and the fast rear gears, but thanks again.
__________________
Cody, Calgary
AB Chapter Leader
  #10 (permalink)
Old 05-23-2004, 11:10 PM
v8xploder's Avatar
v8xploder is starting off with a positive reputation.
your combo is good for high 12s actually. It wont because its a truck for one, higher up/wind resistance, elevation, driving skills, there are a thousand factors that effect this but 350 horsepower should push a 3650lb vehicle to 12.70. if everything is perfect. there are a lot of calculations a guy can do to figure out this stuff.
  #11 (permalink)
Old 05-24-2004, 02:35 PM
68 351 bronc is starting off with a positive reputation.
To figure wich gear ratio is right for your truck you need to deside what RPM you want to cross the line at. Then calculate tire highth and the rpm to figure gear ratio. If you go to 4.30s and you run up to 6200 RPM but your 351 only pulls to 5500 and then flatens out you will loose top speed. Go to Randy Ring and Pionion.com. There is a calculator there to determine gear ratios and RPMs.
A friend of mine went to 4.56s in his Chevelle and lost 6 tenths.
__________________
2001 F250 V-10 auto XLT 4X4
68 Bronco GT40 351w, NV3550 5sp, sweet!!!
  #12 (permalink)
Old 05-25-2004, 01:26 AM
mustange70's Avatar
High 12's, wow i would have never thought, but i guess i need to get it to launch before i can do that.
__________________
Cody, Calgary
AB Chapter Leader
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
