7.3L Navistar Turbo Diesel VS. 7.3L Power Stroke Turbo Diesel - Page 9 - Ford Truck Enthusiasts Forums
  #121
Old 05-16-2011, 11:26 AM
84-6.9L's Avatar
84-6.9L 84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
OOOOOOOOOOO, another old thread. Anywho on the 5.7 gm diesels, the head bolts werent nesesarilly small, they are 1/2"IIRC. BUT they didnt use enough of them. I heard it was because they wanted to share the tooling with the gas motors. Our IDIs have 34 head bolts and the 5.7's have 20. They also have a timing chain set. Which works great but isn't as reliable as gears. The 6.2's and 6.5's were better with the same 34 head bolts the IH's have.
They weren't built to be pulling motors gm built them more for milage. My old 90 F-150 300-6 RIP would out pull my dads 88 2500 with the 6.2 and not even complain. same 20ft car hauler same 120 72lb bales The ol 300 would slow on the hills but not as much as the 6.2 and also wouldn't be running 240*coolant temp at the top.
When i had my idi apart for rear brakes i drove the 6.2 for a few days til my drums came in, and it was SLOW i felt like is was in everyones way, but i did get 23mpg!
  #122
Old 05-16-2011, 02:36 PM
Country_boy_2007's Avatar
Country_boy_2007 Country_boy_2007 is offline
Country_boy_2007 is gaining momentum as a positive member of FTE.
i have to agree with 84, the 6.2 is actually a pretty good little engine, you just have to be patient with it. it'll get ya there...with awsome fuel econemy...it just takes longer. driving the old 6.2 we had was like driving miss daisy.
  #123
Old 05-16-2011, 04:32 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
Good god I hate that engine with a burning passion, anyone who thinks it has any good parts about it shoudl drive a HMMMV. It is pathetic even the soft top light version that looks semi-looks like a pickup is gutless. the 6.5....still gutless even with a turbocharger on it. The Canvas topped ones....0-60....roughly 45 seconds...you have to stomp on it to get it to even move the HMMMV. The military also put these in blazers...still gutless with less vehicle to pull around. It gets crappy mileage too...MAYBE 15 on a day you baby it on the highway @ 55 mph with a tailwind.
  #124
Old 05-16-2011, 08:17 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
Just had to replace the injector pump on my dad's 93 6.5 TD. Took over 2 hours just to get the old one out. I can R&R the pump, lines and injectors on a ford IDI in that time!
Finally got it all back in and too FOREVER to prime. GM put the injectors under the valve covers which not only makes it harder to reach but also increases the injector line length, so air takes that much longer to purge.
Having said all that, the truck pulls great now, and its smooth and quiet, so he's happy. We'll see if it can ever get the sky high MPGs I hear they should be capable of now that it has recent nozzles, timing chain, and a new injector pump. Best we ever saw with the truck was 18~19 MPG with a bed cover and speeds below 70 MPH (on high sulfur diesel!).
I'd consider using a 6.2 in a half ton truck with overdrive transmission, however after seeing what the heavier 6.9 can do in a half ton, I'd just as soon go that route.
Sorry for the rant, I'm still sore in places I didn't know I had after squatting under the hood of that engine for hours on end. LOL good times....
  #125
Old 05-16-2011, 11:02 PM
84-6.9L's Avatar
Quote:
Reminds me of putting my turbo kit on!
  #126
Old 05-17-2011, 07:59 AM
mechelement's Avatar
mechelement mechelement is offline
mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.
Quote:
The military equipped the HMMWV and CUCV with the 6.2L for a reason and they get poor fuel economy because of their gearing, tires, the environmentally friendly fuel they run and the overall shape of the vehicle. The 6.2L is a good motor when you actually go through it and fix the known issues with the motor... just like every other older mechanical diesel motor. I read a nice write-up on a 6.2L build. When it was finished and dyno'd it had more HP & torque than a brand new Duramax.
  #127
Old 01-19-2014, 02:00 PM
coggini coggini is offline
coggini is starting off with a positive reputation.
pre powerstroke
450,000 miles still pull anything you can hook to it. still all original engine
1989 E350 7.3 IDI engine swap tips danyrock 1968-2013 Full Size Vans 6 07-05-2016 12:28 PM
1994 7.3L swap with 1998 7.3L JJtheGent 1994.5 - 1997 7.3L Power Stroke Diesel 15 02-24-2015 07:07 AM
94.5 7.3l is it a powerstroke or what? ford diesel man 1987 - 1996 F150 & Larger F-Series Trucks 10 01-31-2011 07:55 PM
V10 guy asking Diesel questions!!! armynavyguy 1999 - 2003 7.3L Power Stroke Diesel 29 04-20-2008 03:39 PM
Tags
73, camless, diesel, direct, engine, idi, indirect, injection, navistar, owners, power, powerstroke, specifications, stroke, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
