Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-10-2004, 07:48 PM
greenterror is starting off with a positive reputation.
Lightbulb air box or heat shield
trying to find out what i need to fab one up for a 2002 explorer with fipk
  #2 (permalink)
Old 04-12-2004, 12:23 AM
CobraXP's Avatar
CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold
What are you trying to make - something like a K&N or MAC setup? Are you wanting an open air filter like the FIPK kits?
__________________
David
FTE Super Moderator
Join us in the Utah Chapter!!!
When you can't buy what you want, build what you want.
  #3 (permalink)
Old 04-14-2004, 08:56 AM
low-side is starting off with a positive reputation.
Heat shield should be fine. As I recall they mount the filter pretty close to incoming air so if you just fab some sheet metal to shield it from your manifolds it should be okay.
  #4 (permalink)
Old 04-16-2004, 07:27 PM
maypo's Avatar
maypo is starting off with a positive reputation.
I just put one in on my F250 5.4L. The K&N came with a heat shield. If you need one then sheet metal with rubber around the edges to protect you and your hoses will do fine. Mine attached to the bottom 2 bolts of the evaporative canister.
__________________
03 F250 XLT 5.4 4x4 SD CC
8' Fisher plow
Sport Master soft tonneau cover
Duraliner bed liner
K&N FIPK
PIAA headlight bulbs
50w halogen backup bulbs
Rear Marker lights
55w aux b/u lights
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
