Heater/Wiper
Heater/Wiper
Can anyone tell me how to get the heatermotor demonting?
I can`t find any screws in the engineroom.
Also, there are two wipermotors in my truck, but they are not atached to each other,
just the motor right on the wiper with wire connected to them.
Is there something missing, or is this some aftermarked stuff?
That means I'll go out to my garage and take a look. OK, I did, there should be 3 nuts holding the heater box to the firewall. One of them is between where the heater hoses go on the heater core, so it might be a little hard to see. Let me know if you need a picture and I'll go out and snap one.
Ron
Ron
Just thinking?
Thanks Ron the pictures.Just what I needed.
But I start thinking: The heater stoped after a few minutes, my car have a 12v system, with new wiring, is all the heatermotors 6V or is there 12V motors?
The heatermotor is as far as I can tell original.
Can there be a regulator 12V-6V in the heaterswitch, I saw a extra wire with orange color, a loose end at the switch and a loose end at the heatermotor.
Greatful for any answers
on
What year is your truck? If it's a 56, the heater motor will be 12V. If prior to 56 and it's the original heater, it will be 6V. I've seen 6V heaters run on 12V system through a rheostat and as long as you run it on low it will last a long time. However, if you push 12V through it, it will fry which may have already happened...
Vern
I see from your profile that you have a 55- that means an original 6 volt heater motor. If you are using 12 volts without a voltage reduction youve just fried your motor. You have two options-either buying a new 12 volt heater motor( I bought mine from mid-fifty)or you can have my old 6 volt motor for free but then you must use a voltage reducer.
Not sure anymore
I thought I have a 55, but I am not sure anymore:
There has been done a lot of changes on my truck, more and more is discovered as I demont. the car.
So I can`t really tell if the heater is 12 or 6 or a 55 or a 56
I primed my hut today, and discovered brakefuel leak, petrolleak, and a lot
of screws that is loose, and I meen a lot
Also tried to figure out the new wiring, I seem to have two sets of instruments, the originale, and some extra round type.
And they all ends up in the engineroom, NOT CONN TO ANYTHING
Must say, this is not one of my good days
Why can`t people just stick to the originale
i`m sorry to hear this Helge, hope you can clear all your electrical problems soon. i know how you feel right now cause i have the same problem. 50 years of loose ends , double wires that go to nothing and back + past the firewall !!!!! All easter holiday i`ve been tearing out old, broken as useless wires(a full plastic bag!!)
All new wires are being laid out now, also got hold of a 7 series BMW fuse- box to be hidden(incorporated) in front / left kick-panel, with a 6.5"woofer alongside. must also find a heater-box from a donor-car when it is up and running again.
keep us posted helge.
steven
steven
on
According to the pictures of the truck in your gallery it looks like a 55 to me. So, if the heater is the original and the heater motor was not changed to 12 volts, it is a 6 volt heater. Sometimes it's easier to tear out all the old wires and just start over with a new harness than to try and track down the old ones...
Vern
A new day...
Yes Greatnorthwood, I agree, byt my trouble is that the preowner have changed to a new wireset from Johns F-Fun but there is a lot of wire ending in nothing in the engineroom, and there are no documentation on where to conn. these loose wire.
One ex. there are a tree or four wire going from the dash instrument to the engine, one red/white to the ground of the coil, and one white/red that seem to fit to the tempsender unit in front, but I don`t know. Also a brown wire conn. to nothing and anotherone going to a sendingunit in front of the carb, oilunit a guess.
If someone have a diagram of the wireset from Johns F-Fun or a really good idea how to do this, I will be wery, very greatful, It is still cold here in Norway
on
Helge,
I would not be overly concerned with wires that end up in the engine compartment that are not connected unless something that should be working is not working. It is possible that the wires are extraneous. Perhaps the PO got a wire kit that included a future installation of A/C, or it could have been for an electronic ignition that is not installed, or for an electric choke which may or may not be present, an electric fan, etc., etc., etc. There's just no way to know that without the instruction sheet. Some of the better wire kits like Ron Francis and Painless have the purpose and destination of the wire marked on the wire itself every few inches. Have you checked that? Can you determine the manufacturer of the wiring system? It may be on the fuse box. I do not know offhand what brand of wiring kits John's F-Fun carries, but it is probably one of the major manufacturers of wiring kits. Even within wiring kits there will be differing instructions for different model kits, so what you really need to come up with is the manufacturer AND the kit model in order to locate the instructions. I hate to say it, but you may be better off starting over with a new kit if you are unable to trace down the wires...
Vern
Vern
