Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-10-2004, 02:59 PM
coplin's Avatar
coplin coplin is offline
Garage is empty, add now
coplin is starting off with a positive reputation.
Base Timing on a 2.3L ?
anyone online right now?
__________________
White on Grey 2001 F250 Lariat 4x4 Crew Shortbox SRW .7.3L PowerStroke.Rare Forged Rods.Engine- Canoa Plant Brazil.Truck built Kentucky plant.Rolls On Cooper 35's.Chrome mags,chrome mud flaps 4 inch magnaflow Chrome fat tip. LED under tailgate bar.Autometer tri gauges.Foil Delete.K&N. 30,000lb Gooseneck.C-better mirrors.
  #2 (permalink)
Old 04-10-2004, 03:07 PM
King Triton's Avatar
King Triton King Triton is offline
King Triton has much to be proud ofKing Triton has much to be proud ofKing Triton has much to be proud ofKing Triton has much to be proud ofKing Triton has much to be proud ofKing Triton has much to be proud ofKing Triton has much to be proud ofKing Triton has much to be proud ofKing Triton has much to be proud of
That little dot next to your name,when it turns to green,it means they are online,
Whats up?
__________________
Disclaimer: Not safe for human consumption by those allergic to smoked meat.
  #3 (permalink)
Old 04-10-2004, 03:10 PM
coplin's Avatar
hey there how do you set base timing on a 2.3 liter ford?
__________________
  #4 (permalink)
Old 04-10-2004, 03:23 PM
Yes there is a little gray plug close to your distributor,unplug it,then set your timing to 10deg before tdc.If you need me to go into greater detail just shout.
__________________
  #5 (permalink)
Old 04-10-2004, 03:30 PM
coplin's Avatar
yes aliitle more detail please, I know about the spout but where do you physically set the accesory shaft/sprocket when doing timing belt change out to get the initial base timing set after that the computer does the rest??.
Also have some codes for you
223:dual plug inhibit_ what's this mean?
224:IDM input?
Thanks
__________________
  #6 (permalink)
Old 04-10-2004, 03:36 PM
Well,ya got to give me a little more to go on,first what year is it,second are you asking me where to set the crank and cam alignment marks,
__________________
  #7 (permalink)
Old 04-10-2004, 03:40 PM
coplin's Avatar
its a 92 no dist.and its the 3rd shaft i need to know how to set.there is a mark on the pulley but nothing to reference it to
__________________
  #8 (permalink)
Old 04-10-2004, 04:32 PM
ok,first the aux shaft does not need to be timed,and your IDM is Ignition diag monitor, and both of those codes could be related to your crank sensor,which leads me to more questions,did it the old belt break,is this a no start?And sorry it took so long to get back to ya,I have kids and get(but dad i need it for homework).
__________________
  #9 (permalink)
Old 04-10-2004, 05:07 PM
coplin's Avatar
no breaks, but belt is worn out. it does start but is rough.the only info i could find seemed to indicate primary ign so maybe it is related to the crank sensor. thanx for all the input tho.
PS i know how the parenting thing goes myself!
__________________
Tags
2001, 2003, 23, 23l, 23liter, 73, base, diagram, engine, ford, ignition, liter, set, setting, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
