Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
  #1 (permalink)
Old 04-10-2004, 02:16 PM
brandonslightning brandonslightning is offline
Garage is empty, add now
brandonslightning is starting off with a positive reputation.
Exaust Help
Hello, could someone help me on some questions I have about my 93 lightning. I would like to ditch those exuast resognators, but there are air tubes from the smog pump in them. Any ideas? Can I get rid of the smog pump without turning the check engine light on? I live in an area where there are no emission restrictions.
  #2 (permalink)
Old 04-10-2004, 08:17 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Those are cats, not resonators. Don't bother removing the pump or emissions equipment. It will not really gain you anything and it will polute the air more and is still illegal. What you can do, is replace those cats with hi-flow ones. Summit racing or similar has them for about 60 bucks.
__________________
Justin
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
  #3 (permalink)
Old 05-02-2004, 01:46 PM
ClemsonLightning ClemsonLightning is offline
ClemsonLightning is starting off with a positive reputation.
Gt221 and I seem to be at odds on the emissions issue. But oh well, here's the non-tree-hugger's side.
Bassani does make and off-road H-pipe without catalytic converters that is suppose to bolt right up. I assume they have the fittings for the air lines as well. I'm looking at getting one next month.
I continue to run the smog pump on my truck because I have over 135k on the odometer. The smog pump pulls a vaccum on the crankcase which helps keep the piston rings sealed. Many racers are using vacuum pumps now so they can run less ring tension and free up some horsepower. If your engine is relatively new, you my free up 2-5 hp by not turning the pump, but the performance difference you gain would like running on 2 full tanks of fuel versus 1/4 of a tank. Ditch the cats and keep the pump is my $0.02.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
