Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-10-2004, 12:39 PM
equium is starting off with a positive reputation.
Where did you put your CB antenna(s)?
I got the cowl off of my '91 F250 and was thinking about single or twin CB antennas on the fenders. I then found some stake bed hole monuts. so, where do you all have your CB antenna?
__________________
99 XLT Clubwagon E150
5.4 Triton
11 passenger
91 F250 XLT Lariat (4X2)
7.3L IDI
  #2 (permalink)
Old 04-10-2004, 01:27 PM
Spectramac's Avatar
Spectramac is gaining momentum as a positive member of FTE. Spectramac is gaining momentum as a positive member of FTE.
You could get those little stainless brackets that mount in the hood-to-fender crack. Keep in mind that if you go with duals, they need to be as far apart as possible to keep the SWR down. I just slapped a cheap magnet mount on the hood and ran the cord through the door.
__________________
Malcolm
97 Explorer 5.0 AWD
87 F250 6.9 CTS turbo
  #3 (permalink)
Old 04-10-2004, 08:54 PM
RawPower's Avatar
RawPower has a very good reputation on FTE. RawPower has a very good reputation on FTE. RawPower has a very good reputation on FTE. RawPower has a very good reputation on FTE.
I bought mine with the CB installed by the previous owner, who had it mounted at a CB shop. The antenna wire was run through the firewall, then under the cab and up between the cab and the bed. He had the antenna mounted in the center, but that was gay, so I moved it. I got a 90 degree elbow mount and drilled it into my tool box on hte left hand side...
__________________
1993 F350 7.3 IDI, ZF S5-42, TS Div205, OEM/welded Rock's, 46's, 145" wheelbase
  #4 (permalink)
Old 04-10-2004, 11:40 PM
bchunter's Avatar
bchunter is starting off with a positive reputation.
Mine is on the drivers side front fender, mounted with the steel L bracket that Spectramac said. Actually, it is a VHF, but my old truck had the CB antenna in the same place. When I get a CB, it will go on the other fender.
  #5 (permalink)
Old 04-11-2004, 03:18 AM
Quote:
Originally Posted by RawPower
... antenna mounted in the center, but that was gay...
LOL. i just woke up the wife laughing at that.
i'm starting to like the "behind the cab" look. keep 'em comming, thanks
__________________
5.4 Triton
11 passenger
7.3L IDI
  #6 (permalink)
Old 04-13-2004, 01:16 PM
FireMarshal3311 is starting off with a positive reputation.
Man, that's harsh, I use to have mine mounted in the center on my tool box
I know have mine mounted in the center of the cab roof, I just need to ge a new whip, some one unscrewed the old one, darn thieves
__________________
---Fire Prevention is Everyone's Business--
  #7 (permalink)
Old 04-13-2004, 03:47 PM
RawPower's Avatar
You should have welded it to your truck... not really...
Thats what thread-lok is for... and a 12ga in case you catch em in the act (just kidding I wouldnt kill someone over a CB antenna, Id just whip them with it for a long time).
Did you mount it in the center or was that how it was when you got the truck? I cant deal with it like that. When you look in your rearview you have a line in the middle o' your window. Maybe thats just my "OCD" (no I havent been diagnosed with OCD, but I might as well have been).
__________________
  #8 (permalink)
Old 04-13-2004, 04:42 PM
bchunter's Avatar
I had an 80 chev 4x4 that I had the antenna sticking out of the middle of the roof, but then my buddies started calling my truck "Pebbles" like Fred Flinstones little kid. I moved it to the hood pretty quick
  #9 (permalink)
Old 04-13-2004, 07:43 PM
c_nate is starting off with a positive reputation.
the best place as far as making for good reception was in the middle of the cab roof. but the ended quick as the antenna broke of from driving though trees, so put it on the drivers side front corner of the bed with a big old bolt though the top of the bed.
run the cable though the fire wall, though the boot that is around the steering column.
Nate
__________________
1994 F250 4x4
7.3 IDI factory turbo
  #10 (permalink)
Old 04-14-2004, 08:28 AM
One cowboy is starting off with a positive reputation.
I'am going to put mine on the headace rack , I just got from a buddy of mine , now where to put my Galaxeis(sp) 44 that's all super turned
onecowboy Alvin TX
  #11 (permalink)
Old 04-14-2004, 10:53 AM
redneckmechnic is starting off with a positive reputation.
i had my cb antena in the stake pockets of my chevy yes i no this is a ford site but we all make mistakes. I had one on each side looked pretty good. On my ford i have them mounted on the mirrors. again one on each side but this time the drivers side is for the cb and the passenger side is for the am fm radio since the orginal factory antena never came with the truck and cb wips are much cheaper.
__________________
85 ford F 250 6.9l 5 speed 4x4 7.5ft snow plow flatbed with dual 4inch stacks 270,000 miles and counting
  #12 (permalink)
Old 04-14-2004, 10:58 AM
sglaine's Avatar
NH Chapter LDR
sglaine has much to be proud of sglaine has much to be proud of sglaine has much to be proud of sglaine has much to be proud of sglaine has much to be proud of sglaine has much to be proud of sglaine has much to be proud of sglaine has much to be proud of sglaine has much to be proud of sglaine has much to be proud of
Smile
When I had 1986 - 1995 I mounted mind on the mirrors and ran the wire though the vent window.
__________________
00 F350 4x4 Power Stroke 6spd drw rack body 4.10
02 Explorer XLT 4X4 Red
03 Explorer XLT 4X4 Aspen Green
04 F250 4x4 5.4 6 spd pickup 3.73
Leader of the New Hampshire Chapter.. Come And Join - CLICK HERE
Quote:
Originally Posted by SteveBricks
She looks like the south end of a northbound mule
  #13 (permalink)
Old 04-14-2004, 10:29 PM
84deisel's Avatar
here sometimes
84deisel is starting off with a positive reputation.
I have mine mounted on my mirrors.I have the camper special mirrors . Drilled a hole in door just below mirror bracket and ran wire through door. Did the same on other side and then ran both wires up to center of inside windsheild trim and used a two cable into one cable to back of cb. They are tall enough to let me know the height of low overhangs so i dont shave off my lightbar that is on my headache rack.
__________________
2002 f250 4x4 supercab 7.3psd auto,81 f100 4.9 auto fully restored, 96 ln8000 8.3 cummins allison 12' flink plow 10' flink ss salt spreader and way to many ford company trucks to list
  #14 (permalink)
Old 04-16-2004, 09:09 PM
Tarzan's Avatar
Tarzan is starting off with a positive reputation.
the best place is the middle of the truck. but mine is on the right side on the outer part of the toolbox and i put a heavy duty spring on mine cause i would hit everything i went under in my 4wd chevy,(wouldnt trade it for the world), just allows it to have a little more give.. also, keep the coax in 3 foot increments to help on the swr. if yall are ever around b/cs texas, holler for tarzan, i might be out there.
__________________
94 F350 4X4 7.3 turbo diesel 4 door w/ 33s front and back replacement bumpers, no muffler 220,000 "saw em off"
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
