Has anybody swapped a 5.4 out of a 2000 Expedition into a 99 F 250 Super Duty? The engine in the SD seized and this is the closest replacement engine we can find. Any help would be appreciated.
I believe this is probably true. We're going to try it . It should be the same basic block and we can swap the electronics to the donor engine if necessary.
Considering that both are relatively new motors, I doubt you would even need be concerned with the electrinics swap. I'm "guessin" this will be a direct move of the block and you are set to go...
Good luck --Mike
__________________
Mike G
1965 F100 LWB .060 over 390/beefed C6
1968 Cougar XR7 (wife's toy)
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
2003 XR50 w/big bore 80cc kit
1990 Chaparral 2000SL 20ft bow-rider 5.7L Merc
Yes...there are only three licensed drivers in the household
