Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-10-2004, 08:44 AM
fishin machine is starting off with a positive reputation.
393 stroker?
I have a 93 Bronco w/ 351w efi. I want to build a 393 stroker for it. What wold I need to do computer wise to get it to run.
__________________
93 EB BRONCO
351w
Edlebrock 60329 heads/Intake
Comp Cam 35-255-5
Roller Rockers
Headers/True Duals
Walk my post from flank to flank and take no ****** from any rank.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-10-2004, 06:36 PM
fordeverpower's Avatar
fordeverpower is starting off with a positive reputation.
Nothing really, you are just gaining cubic inches from more stroke. Everything should run good.
__________________
Matt
79 f150 390 4x4 c6 RIP
78 F100 390 2wd c6
  #3 (permalink)
Old 04-10-2004, 11:26 PM
mustange70's Avatar
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
You might want to get a chip for it so you can get the most out of the stroker kit.
__________________
Cody, Calgary
AB Chapter Leader
82' Flareside: 2/4 Drop, 350hp 351W, Custom interior
81' 250 mudder: home fabbed lift & dana 60 SAS , 450hp 400, 4sp/205, 38" tsl's
  #4 (permalink)
Old 04-11-2004, 06:30 PM
IRULE is starting off with a positive reputation.
stock heads will limit you on power as far as what the motor is capable of. plus if your bronco is speed density,you should probably change it to mass air. or you could save a %$#@load of money and out a carb on it.
  #5 (permalink)
Old 04-11-2004, 06:57 PM
94F150-408 is starting off with a positive reputation.
If your not running mas alrealy then your going to be bettor off with mas on that combination. You will need to up your injector size and I would get a larger Mas from Pro-M with a map to give to your computer guy to set it all up for that much motor. The 19lb injectors were barely adequate for the stock engine. Your computer is fairly limited on the mods that can be performed to it. You might look into a Mustang computer to run your works. The computer you choose will depend also on which tranny your Bronco has in her now. You will have other mechanical upgrades that should be performed to fully achieve the HP potential of that big of a small block.
__________________
94 F150 4x4 393 Stroker
95 Bronco- 408 SuperCharged
Mods in Gallery
  #6 (permalink)
Old 04-12-2004, 01:14 AM
mustange70's Avatar
If youuse your stock heads and install bigger valves don't go bigger than 1.93's for reasons of relielablility
__________________
Cody, Calgary
AB Chapter Leader
  #7 (permalink)
Old 04-12-2004, 01:24 AM
those 19lb injectors are good to 300 horsepower!
__________________
Matt
78 F100 390 2wd c6
  #8 (permalink)
Old 04-12-2004, 12:06 PM
19's will support a MAX of 243.5 HP with the stock fuel pressure. I would hope a stroker of that size is making alot more power than that. Depending on the engine build, 30lb injectors will support 384 HP, so the 30's are probably more in the ballpark for this engine.
1.93's or < valve size and dependability issues, why is that?
__________________
Mods in Gallery
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
