Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-09-2004, 11:33 PM
motorcyclist is starting off with a positive reputation.
plug gap with pertronix?
I just installed a pertronix igniter 2 and flamethrower coil, eliminated resistor wire so coil uses full 12 volts, was wondering how wide of plug gap others are running with this set up?
__________________
Bill, in state of WA.
64 F-250 Custom Cab
292, 4 spd
Dad bought it new when I was six
  #2 (permalink)
Old 04-10-2004, 09:07 AM
57_ford's Avatar
57_ford is starting off with a positive reputation.
When I ran a pertronix 1 I had spark plugs set to 35 I didn't try to set them maybe I should have. It ran good their when the pertronix failed I installed a mallory unilight ran good at 35 then I opened them up to 40 and may try 45 opening up to 40 made a noticable increase in power and is running cleaner. Let us know what you find out.
  #3 (permalink)
Old 04-12-2004, 09:22 PM
46 Y-block is starting off with a positive reputation.
I have a Pertronix 1 with flamethrower, no ballast resistor, plug gaps are 40.
  #4 (permalink)
Old 04-12-2004, 10:16 PM
hi guys, Thanks for the feedback. am going to try .040 and see what happens.
__________________
64 F-250 Custom Cab
292, 4 spd
  #5 (permalink)
Old 04-13-2004, 12:43 PM
Jag Red 54's Avatar
Jag Red 54 is gaining momentum as a positive member of FTE.
Question
Why are you guys removing the balast resister? Does this help the spark with the pertronix/flamethrower combo? I never heard of this before. John
__________________
54 F100
55 Fairlane
68 F100
55 Crown Victoria
  #6 (permalink)
Old 04-13-2004, 04:21 PM
plug gap with Pertronix
The instructions that came with either the Pertronix or flamethrower said to remove the resistor, although it was hard to find that little piece of info. I was more than happy to get rid of a couple extra wires and that hot piece of ceramic.
As I understand it the flamethrower has the required resistance built into it. However if you forget and leave the ignition on, the coil may overheat and become damaged.
  #7 (permalink)
Old 04-13-2004, 04:29 PM
Jag Red 54's Avatar
Thanks for the info. I learn something new every day. John
__________________
54 F100
55 Fairlane
68 F100
55 Crown Victoria
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
