04-10-2004, 09:37 AM
If you are talking about the vacuum lines, that should be mounted just to the side of the injection pump. The rest is described by Birken above. Be careful how you reinstall it, there are tabs inside that match up to the throttle shaft. Easy fix.
__________________
2000 super duty f-350 crew cab with training wheels, ats flip chip controller - hang on to it ! I did the air intake too - best thing since sliced bread.
