1952 F6, what 4 speed is in it ?
Barry, hi, thanks, its a T98 then the dash says synchronized right on it, i forgot actual wording
you happen to know what splines input shaft would be and what the ratios would be ? also what pattern is front of case, normal four-bolt, or ?
thanks
thanks
The parts book shows a ratio of 6.40 to 1 ratio. If you grab this tranny ( and I would because they're rare!) Grab the bellhousing, clutch and all linkage. Don't leave anything. Grab the rear mounting hardware, etc.... It will bolt up in the smaller trucks, Looks like 17 teeth on the imput shaft. There's no individual ratios listed in my books.
Barry
Barry
Sam's comment made me go back and look at the original post - we may have missed something. If he has a 4 spd, Rev is right and down.
Rev up and rt was the position on the 5 spd tranny's in the F7 and 8's.
(According to the Operator's manual for '48 - gears ratios remained the same thru '52)
The F7 had a 5 spd with 5 being an OD gear. Shift pattern as follows:
2-5-R
3-4-1
Synchro'd on 3,4,OD
F8 had a 5 spd with 5 being straight 1:1 Shift pattern as follows:
2-4-R
3-5-1
All straight cut (spur) gears
This was standard equipment for these trucks. Both trannies were optional in opposite rigs.
2-5-R
3-4-1
Synchro'd on 3,4,OD
2-4-R
3-5-1
SparksCCC
10-29-2014 04:31 PM
